How many inches(that is not a sexual reference lol)
Whoknowsbruh
Should I get 1 27 inch gaming  moniter or 2 24 inch gaming moniters?
why not 2 27 inch
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
2 minutes ago, TechGuyMark said:
does'nt fit bugdet
Without knowing your budget, your pc specs, what you need the monitors for, and the models you are looking at its impossible to give any advise
I have 2 27 inches and its awesome, I recommend one larger  one as games don't work on both monitors at once. it works for three if you want to do surround gamin
I have a 27 inch monitor and I am so happy I got it. I initially thought it might be too large but when it arrived it is perfect.
CPU: i7 4790K @ 4.5ghz | Mobo: Asus B85MG | RAM: Corsair Vengence 16GB 1600Mhz | GPU: R9 390X
SSD: Kingston 240GB | PSU: Corsair CXM 600W | Case: CIT Dominator + 6 Corsair AF120 Fans all around |
CPU Cooler: Cooler Master TX3 | Monitor: BenQ XL2730z 144Mhz 1440p |
Keyboard: Corsair STRAFE | Mouse: Razer DeatherAdder Chroma
Monitors at both 1920x1080 and 2560x1440 come in 27" dimensions. We cannot possibly answer the question without at least knowing what resolutions we're comparing.
both are 1080p
9 minutes ago, TechGuyMark said:
both are 1080p
I would personally take the 24" 1080p monitor(s), because I usually feel like 1080p stretched out to 27" gets a little too pixel-y for my tastes. It would be best if you could see it yourself, maybe at a store with display models set up.
I ran 2x AOC G2460F 24" screens at 1080 for a long time and it was a great set up. if you're staying at 1080 then as above I personally wouldn't go 27", for 1440 sure.. but not for 1080 :)
CPU: i7 7700k. MOBO: MSI Z270 Gaming Pro Carbon. RAM: 32Gb DDR4 Team Group Dark Pro 3k . GPU: EVGA GTX 1080 FTWx2. Storage: 64GB SSD, 250GB SSD,480GB SSD, 1.5TB HDD. PSU: EVGA Supanova 750W G2. Case: NZXT H440 Matte Black. Screens: Acer Predator X34 @ 100Hz & AOC 24" G2460F 144hz. KB: Logi G810 Orion Sprectrum. Mouse: Corsair Scimitar RGB Audio: Edifier S550's & ASTRO A50's. Console Peasant?: PS4 & XBone.
I play PC games on my 50" 1080p TV at about 6 feet eye-distance.   I'm perfectly happy with it.  Do I notice a difference between it and my son's 24"?  Sure, but it's not bad.  I wouldn't play like that if it were.  If the image quality of the 24" has a baseline "score" of 10 out of 10, I'd say the 50" is a solid 7.5 - 7.8 out of 10.
I don't think you'll notice a difference between 24 and 27 inches.  3 inch difference is nothing at that size.
