USB vs Audio jack sound quality
Short answer: the two can't be compared.
One is digital and one is analogue.
It depends on the hardware driving it and what you're listening to (what headphones/speakers) as to whether it's high quality or not.
The USB signal will have to be converted to analogue at some point to drive your speakers/headphones.
Once it's converted, it's "the same" as the audio jack output.
The difference really is where in the chain it's converted from digital to analogue.
USB is converted to analogue in the device which is connected.
Your audio jack output is from a DAC within the device you're connecting to (phone/PC/etc.)
Why are you asking? We'll be able to give you some more helpful advice if we have this information.
Sorry if this is a poor explanation, but like I said, let us know what this is regarding and we can give more helpful advice.
Hope this helps
