It depends on the CPU. For some, the stock cooler works great, for others, the best water coolers can't keep up.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/605718-best-cpu-cooler/#findComment-7847205
the NH D15 and DRP3 are better than 120 rad coolers
anything below a 240 isnt worth it for liquid cooling
if you want to liquid cool, get a 240 or 280 rad AIO
https://linustechtips.com/topic/605718-best-cpu-cooler/#findComment-7847226
8 minutes ago, jackreading007 said:
ok this is my first build and have been told to keep my inside case temps as low as i can.
should i go with a air or liquid cooler? would be between the noctua dh14, dark rock 3 or a corsair h60 or some sort of 120 rad cooler?
I would recommend using the stock Intel cooler, it does a great job.... :)
Seriously tho, the best thing to do would be this...
The bong CPU cooler
If unreasonable, the next bets thing to do would be a custom loop,
then an AIO,
then an aftermarket cooler.
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/605718-best-cpu-cooler/#findComment-7847231
28 minutes ago, aisle9 said:
120 rads are for SFF builds only, where a quality air cooler or 240+ rad won't fit. What kind of case do you have?
im getting a nzxt340 but you can only have a 240 at the front and only with fans at front side of pc on the rad not on the internal side of it. so would be having the fans blowing out the front to exhaust the hot air instead of into my pc therefore i was going to have 2 140 intake fans a rear exhaust and a top mounted 120 rad or another 120 fan with air cooled cpu.
https://linustechtips.com/topic/605718-best-cpu-cooler/#findComment-7847492
Having a front mounted rad works just fine and doesn't warm up the air that comes in much--maybe a few degrees at most.
280mm rads fit in the front.
https://linustechtips.com/topic/605718-best-cpu-cooler/#findComment-7847568
