How to monitor/measure power consumption by floor?
2 hours ago, ZeferiniX said:I can't seem to find what I'm looking for on google, probably I'm not looking for the right term, I've only found solutions on monitoring appliances specific to the outlet. I don't have much background on this area so I'm having trouble on what to do either. So how do I go around this? Basically, I just want to monitor only the power consumption on the second floor (yes, including lights), get the total kilowatts then deduct that to the monthly kilowatts and observe how much power the second floor is consuming.
Depending on how your house/building is wired up to the breaker panel, you probably can't.
To measure everything, including the lights, etc, you'll need to ensure the following:
1. All electrical items, outlets, lights, etc, on the 2nd floor are on ISOLATED separate circuits. If one circuit has some lights on the 2nd floor and some lights on the 1st floor because it was convenient to run the electrical wire that way, then your whole plan is bust and impossible, without the assistance of an electrician (Do not attempt this yourself unless you're an electrician, you can easily kill yourself with the voltage and amperage involved).
2. Assuming all items on the 2nd floor are on separate circuits, you'll need to wire in a Kilowatt meter (whatever brand of power meter you want, really) directly into the service panel for each circuit. You can buy more expensive units that can accept multiple circuits to measure them all, and even get "smart" units.
In either case, rewiring of the breaker service panel will likely be necessary, and unless you're an electrician, you should stay away from doing that.
If you wanted to skip the lighting and anything built directly into the circuits, you could install Power Meters into each and every outlet - I mean, that's gonna be damn expensive for the number of meters required, but it's doable (You can get Kilowatt meters for as cheap as $20 or $30 if you're lucky, but multiply that by, example, 40 outlets (or however many outlets on the 2nd floor), and you'll see how the price can jump quickly. And those $20 power meters will be dumb units like Linus and Slick use for PC Total System power consumption (It plugs into the outlet, has a plug on the front, and just displays the power used on a digital display). You can buy more expensive ones that can communicate with each other remotely and even to a central server, but you'll be spending well over $100 each.
The most ideal way to do it, would be to pay an electrician to install monitoring equipment into the breaker service panel, assuming most (or all) of the 2nd floor items are on their own breakers.
