NH-U14s fan configuration
DaShesano
Hi all,
I am currently using an NH-U14s with one of Noctua's 3000 RPM iPPC NF-F12s attached to it. I was wondering if its worth keeping the NF-F12 on the cooler, or if I should replace it with the stock NF-A15, as the NF-F12 only cools 4 of the heat pipes, and the NF-A15 cools all 6, but moves less air.
Thanks in advance
Hmm, worth experimenting with I think.. could maybe try a push +pull config?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
I have noticed that the outermost 2 heat pipes appear to be needed for LGA 2011 chips, as they sit slightly over the IHS for my 6700k.
All of the heatpipes help cool the cpu regardless of the size since they aren't direct contact heatpipes.
The iPPC fan is much louder but performs better. Take your pick of either a quieter or cooler system.
Are your temps much worse with A15 than they are with iPPC?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
