Hello, I'm looking for a new Pc case, since my old pc is to big to bring anywhere.
I want a small case, nothing to big like Manta or Evolv ITX. The best case I found so far is the Fractal Design Core 500, since I heard that it can fit a 240mm rad in the top and a 120 in the back, but I really do not like the look of it.
The Ncase M1 looks great but I hate that you'd have to get low profile fans for the bottom rad and an external reservoir.
The Hardware I have:
Msi z170i ITX Motherboard
2x8gb DDR4 Hyper x Savage
6600K Core i5
GPU: waiting for the new nvidia/amd stuff
Silverstone SX500-LG
3 2.5inch drives (got them cheap so why not 3 :P)
EK supremacy evo
10 10/13mm fittings
10/13mm Tubing
NexXxos 240x30mm Radiator
120x30mm Radiator (forgot the brand)
2X alpha cool 120mm noise blocker fans
Everything less than 200$ for the case is ok
https://linustechtips.com/topic/603028-small-mini-itx-watercooling-case/
fractal design nano S looks awesome and is tiny :D
Builds:
Specs: CPU: I5 6600K (4.5 GHZ), GPU: RX 480 (stock), Mobo: MSI Z170A tomahawk AC, RAM: Corsair 16GB drr4 2600, CASE: NZXT S340, storage 240GB crusial SSD and a 1TB WD HHD
