Hello, I've been kind of wanting to play skryim more, but I want to get some high texture mods and other stuff like that, but I have no idea where to start. I figured since I almost always forget to play it, and end up playing something else instead, maybe modding+tinkering with that would give me more of an incentive to play.
Does anyone know where I should start, what websites/ mods I should browse?
Idk where to even start. Any suggestions for what I should get would be great, thx guys :P
https://linustechtips.com/topic/60227-skryim-modding/
Skyrim 2K textures http://skyrim.nexusmods.com/mods/607/?
i recommend looking around Skyrim Nexus for mods that you like. i can also recommend SkyUI.
Edit: There is also the Flora Overhaul http://skyrim.nexusmods.com/mods/141/? and the SIMM Mod http://skyrim.nexusmods.com/mods/8655/? (I recommend you download this from the Steam Workshop, since it is difficult to install)
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/60227-skryim-modding/#findComment-818179
Do you think sky-ui will work right with nvidia surround? TONS of menu's are screwed up if I try to play in surround, they get ridiculously stretched out :(
And can I use the 4k texture pack? Idk how much vram it uses up, also I think "frostfall" was kind of cool looking, I'm subbed to a guy on youtube that does skyrim commentaries and he used that mod in a ton of his videos, it's really cool, you actively are lowered skills/stats whilst being out in the elements for a long time and have to use tents/campfires to survive
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832237
I don not know if SkyUI will work with surround.
You can try installing the 4K texture pack, but Skyrim graphics mods hogs VRAM, so watch out for that. Lastly, Frostfall is awesome. If you were a fan of old school RPGs it is a must.
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832510
I find the 4k texture pack on the same site right? Just double checking
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832533
I have never tried installing it, but I guess so. Most mods can be found there, but if you can't find, just try to google it.
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832573
oki, thx :D if all else fails I can just play on 1080p instead of surround, should be able to spam out some texture mods, I wanna see how fancy it can look xD
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832582
Climates of tamriel isd great.
Also GameSpot have a weekly YouTube video. "Top 5 skyrim mods of the week". These guys are funny and awesome.
GamingPC: Intel 4770k CPU, 2xMSI 780 GTX Twin Frozr, 16 GB Corsair Vengeance Pro, Swiftech H220 CPU Cooler.
Cookie Cutter Build log
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832719
Here is the list of mods I currently have in Skyrim:
Climates of Temriel
JSwords
WATER
AMB Glass Variants Lore
Book Covers
Skyrim Flora Overhaul - Summer Edition
aMidianborn Skyforge Weapons
Realistic Lighting
Helgen Reborn
Enhanced Blood
Bosmer Armor
Dr Bandoiler
Alternate Start
Immersive Weapons
Immersive Armors
Static Mesh Improvement Mod
Unique Uniques
Theres some other ones that arent listed in NMM and just look like updates but thats most of them. Use NMM and download al mods from Skyrim Nexus.
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832834
@Night tysm I'll look into those, I think I may just play on 1080p and mod as many textures and I can, I wanna see how far I can push it
https://linustechtips.com/topic/60227-skryim-modding/#findComment-832877
Have you modded your skyrim before? If not:
1. Get Mod Organizer. When using the Nexus Mod Manager it'll actually replace the original files, making uninstalling some mods quite troublesome. Mod Organizer saves eveything in a separate folder.
2. Read every description/readme! This is extremely important as a simple conflict may corrupt your save.
3. Get BOSS, it really helps sorting out conflicts and ordering your ESPs.
4. Beware of scripts. If you can choose a non-scripted mod over a scripted one then do so. The problem with scripts is that they cannot be removed even if you uninstall the mod, so always make sure you have a save before you install a script. Some mods do allow you to stop the script before you uninstall it, so even if it can removed it won't do anything.
5. Get the Unofficial patches for the expansions you use. These fix a looooot of bugs.
6. Go look at the ENBs available. These will probably be the biggest visual upgrade you can get. There are a lot of ENBs so it's really up to you to choose your favourite. If your PC is beast then start by checking K ENB, that shit looks amazing.
With that said, here's the mods I use for textures/environment:
Skyrim HD 2k Textures
Grass on Steroids
SkyTEST - animals and predators
W.A.T.E.R.
Lanterns of Skyrim
Project Reality - Climates of Tamriel (this doesn't work very well with some ENBs, so ask in the comments)
Bellyaches Animal and Creature
Bellyaches HD Dragon
Better Beast Races
Ethereal Elven Overhaul
Amidianborn Book of Silence
https://linustechtips.com/topic/60227-skryim-modding/#findComment-833613
What i did was just browse nexus mod website for like 6 hours and downloaded mods 1 by 1 (launch game when done, to make sure it dosn't crash my game if it does delete it)
im at 200 mods now and game is fantastic and im a total noob just read the page below for any warnings or compatibility and you will be fine
https://linustechtips.com/topic/60227-skryim-modding/#findComment-836300
Grass on Steroids
W.A.T.E.R.
Lanterns of Skyrim
Better Beast Races
Is there higher texture packs then that? I can't find them on skyrim nexus, maybe I'm stupid and not searching the right thing >.<
I think ima get that grass on steroid thing you have :o
I'm gonna download that k enb thing you said, I really want to push my pc+ skyrim graphics as far as I possibly can, I want to struggle to get 60 fps, instead of having well over 100 lol
https://linustechtips.com/topic/60227-skryim-modding/#findComment-836507
you have a beast system so i'm going to tell you this right now, Texture Mod Combiner is your best friend. I cannot play anymore without this mod, spend a couple of hours and follow the steps for this mod because IT'S WORTH IT BRO. it basically retextures skyrim top to bottom and it's super customizable so go ham
https://linustechtips.com/topic/60227-skryim-modding/#findComment-837076
Well, there is. As you mentioned before replace 2k textures with the 4k textures
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/60227-skryim-modding/#findComment-837093
The Skyrim HD - 2K textures has 4K textures as well. The full version is mostly 4k, the lite version is 2k.
If you really want to struggle to get 60 fps then there's a very easy way to do it. After you've set your textures and picked an ENB just raise the view distance for grass, npcs, shadows, etc. One thing that really annoys me is how when you can clearly see the grass appearing as you move or the shadows changing the moment you get closer, even if it's like 50 meters ahead of me it's still noticeable and it pisses me off. If I had your PC that would be pretty much the first thing I'd do.
https://linustechtips.com/topic/60227-skryim-modding/#findComment-837182
wewt ok, I'm looking at an enb right now, http://skyrim.nexusmods.com/mods/30936/?tab=1&navtag=%2Fajax%2Fmoddescription%2F%3Fid%3D30936%26preview%3D&pUp=1
Some people on skyrim nexus forum's suggested that one, I may try what you said and just go nuts :D
https://linustechtips.com/topic/60227-skryim-modding/#findComment-837215
once you finish the texture pack combiner, it sohuld be around 10gb of textures, jsut a heads up. Also, that is the enb i currently use, it looks great
https://linustechtips.com/topic/60227-skryim-modding/#findComment-837740
I haven't installed the ENB yet, I kinda just threw everything on the "recommended mods" list in, tried playing and its kinda laggy, I need to re-download precision x's on screen display and see what my fps is later, then go from there.
I'm thinking maybe I didn't pay enough attention whilst downloading everything and maybe goofed something, may just re-download skyrim since it only takes like 30mins with my net and start from scratch and pay more attention lol
https://linustechtips.com/topic/60227-skryim-modding/#findComment-838182
yeah be careful lol don't rush stuff like this
https://linustechtips.com/topic/60227-skryim-modding/#findComment-840328
Ok I got everything installed, looks amazing :o I wanna do more modding with diff packs maybe, I'm gettin 40-60 fps with the enb's presets at "high" with all the crap enabled and render distances on max, its so cool xD using like 2.2gb of vram in 1080p lol
https://linustechtips.com/topic/60227-skryim-modding/#findComment-841589
