Port forwarding is confusing me. Please help
3 minutes ago, Spork829 said:192.168.0.1 doesn't bring up anything either. I can try plugging into the modem with my laptop then going to 10.0.0.1, but would I need to enable that to act as a router first? No idea how I would do that. Also, what should I do if I manage to get into a web UI when I do that?
Jumping in here. From the sounds of it, you have two subnets on the same LAN (your modem has routing functions turned on, and so does your router). The easiest way to achieve what you're looking for is to reset your modem (hold down the reset button for 30-60 seconds), plug directly in to it (with a computer), log in, and turn on "transparent bridging". Depending on the modem, this could also be called "bridging nat disabled", or something similar. This effectively disables all of the extra features on your modem (routing functions, that is) and turns it back in to a good, old-fashioned modem. From here, you can plug your router in to the modem, and then (if you have any wired devices) plug those into the router. DO NOT plug in to the modem, as this will put you on an entirely separate network. At this point, your router will be the only device managing the network, and any port forwarding settings set on there will take full effect.
