So I called this guy on Craigslist who is selling two 780 ti's for $200. Not each... for both. This is a steal right? Like, I should totally jump on this, right? Just wanted to see if you all thought it was a great deal too.
CPU: Ryzen R7 1700X Motherboard: ASRock X370 Gaming K4 CPU Cooler: Corsair H60 RAM: Crucial 32GB 12400Mhz GPU: Zotac GTX 1080 AMP! Edition
SSD: PNY 240GB HDD: Toshiba 3TB 7200RPM PSU: EVGA 1000 GQ Case: NZXT S340 Display: Dell P2416D
Camera: Samsung NX1 Audio: Tascam DR-40 Mic: Rode NTG2
Interface: Focusrite 18i20 Monitors: Event 20/20's Mic: Blue Bluebird DAW: Steinberg's Cubase 7.5, Adobe Audition CC
Guitar: MIM Fender Stratocaster Amp: Peavey Classic Chorus 212 Pedals: Dunlop High Gain Volume, Big Muff Germanium Pi, Boss DD-3 Delay, Roland Tuner
https://linustechtips.com/topic/597785-two-780-tis-for-200/
Yeah it's a steal.
They are aging cards though, albeit quite beefy ones.
 Almost as cool as my temps
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762806
sounds like a scam 200$ never.
PC || CPU - I5 3570K @4.5ghz|| Motherboard - Asrock Z77 extreme 4 || CPU Cooler - Corsair H100 || RAM - 1x8GB Vengeance Blue - XPG Adata 2x4GB's (16GB) || Graphics card - EVGA GTX 970 superclocked ACX 2.0 SLI || Storage- SEAGATE FIRECUDA 1TB ||PSU- Corsair AX750 watt gold rated|| Case- NZXT 340 WHITE
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762808
True, I'm gonna have the guy test them in his rig in front of me.
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762813
2 minutes ago, Benergy said:
Yeah it's a steal.
True, I know they're getting older for sure which is why I asked. But yeah, they're pretty hefty!
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762814
well, if you want to replace your 980Ti... You'll have to deal with SLI and probably need a new PSU, how big was the performance increase from 780Ti to 980Ti?
For a second, new system, it's probably a good bargain
"We cannot change the cards we're dealt - just how we play the hand" - R. Pausch
CPU: Ryzen 7 3700X , Cooler: BeQuiet Dark Rock 3 Motherboard: MSI B450 Mortar Titanium RAM: 16 GB Corsair LPX 3200 GPU: EVGA RTX2070 XC Storage: Adata 120GB SSD, SanDisk 1TB SDD, 2TB WD GreenHDD Case: Fractal Design Define Mini C PSU: EVGA Supernova 650GS Peripherals: Master Keys Pro S, Logitech G402 Audio: Schiit Fulla 2 + Sennheiser HD 650. Laptop: Asus Zenbook UX 302
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762817
Oh it's purely for a second system haha they won't be replacing my 980 ti ^.^
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762818
if you would buy it no post or sending shit you will get scammed 10000% if you want to buy it you have to go to hem and check if they are really 780 TI's i,ve that there are many scammers on craigslist not living in the USA (europe) so don,t know how it works there.
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762820
Considering that 780 TIs in SLI rival a single 980, $200 for both is the bargain of the decade. There is the relatively low amount of VRAM to deal with, but other than that it's worth a buy.
Just make sure they work and he's not fleecing you.
Other systems I've built:
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762821
200 cad is 136 euro that's nothing the lowest priced second hand gtx 780 TI is 250 euro's = 365 cad for one TI dat scam.
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762836
IT would be totally local pickup. I'll be meeting him at huis place and seeing them run in his rig first.
Very true, essentially a 980 for half the price (except SLI headaches). I'll keep you guys updated!
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762837
It's $200 USD
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762838
It's $200 USD
250 euro for 1 780 TI here so 281 dollars rip it just seems so fake but you can be Lucky here buddy.
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762844
We shall see!
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762848
You will be limited by VRAM quite a bit, because 780Ti is around the performance of a GTX 970 usually, but with two of them and 3GB of VRAM this will be a bottleneck, nevertheless for 200$ I'd take it immediately if I needed a GPU
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762901
They don't have much Vram for today's standards, they are quiet old and power hungry. But that price is an insane steal. These cards still go for $400+ each brand new.
The deal smells.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762903
Yeah the 3GB will definitely hurt a bit but it'll only really be for 1080p gaming or video encoding stuff.
The deal smells.
It is a bit smelly isn't it?? We'll see if it's legit or not. Once I see the guy, I'll know whether I'm being ripped off.
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762907
run them for atleast 30 mins :)
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762933
Good idea!!
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7762947
Wowz that's like 970 sli for 200 bucks.
Totally a steal. Even after Pascal and Polaris are officially released you won't be getting that.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/597785-two-780-tis-for-200/#findComment-7765997
