Hi, I recently burned down the power supply, need to buy one but not sure which one, I have an I7, Intel Extreme Mother Bord, 16GB Ram, 5 HD, Corsair Hydro Series H100i v2, some UV Cold Cathode Light Kit, 570 Nvidia Video Card, may be get a new one 970 or 980
I like the corsair, Corsair HXi Series, HX750i, HX850i, Corsair HXi Series, HX1000i
which one do u recommend?
https://linustechtips.com/topic/597661-power-supply/
All of those PSUs are absurdly overkill for a GTX 970 or a GTX 980. Just get a RM550x (or RM650i if you're deadset on Corsair Link).
You should also be looking at the GTX 1070 and the GTX 1080 rather than Maxwell.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/597661-power-supply/#findComment-7761302
Just now, Jorge L. Rojas said:
OK but could you give me a reason,
For what? You're not going to get close to needing 750W with either one of those cards under heavy load, let alone 500W. You're honestly throwing away your money here.
2 minutes ago, Jorge L. Rojas said:
Corsair HXi Series, HX850i why not this one?
See above.
https://linustechtips.com/topic/597661-power-supply/#findComment-7761323
See above.
1. Cooler operation
2. Longer life
3. Quieter operation
If the cost isn't significantly more I'd go for the 750i
https://linustechtips.com/topic/597661-power-supply/#findComment-7761333
9 minutes ago, Windows7ge said:
1. Cooler operation
2. Longer life
Technically true (because Platinum vs Gold) but it's a very minor (or not noticeable) difference for all your points above. Not worth it if the cost difference is large.
Remember the RM650i uses the same FDB fan and has that Zero RPM mode.
https://linustechtips.com/topic/597661-power-supply/#findComment-7761358
Under a circumstance I agree.
If the price gap is large. I say 550W (better value, still good quality)
If the price gap is small. 750W (better deal, slightly higher quality)
https://linustechtips.com/topic/597661-power-supply/#findComment-7761369
I think OP is broken guys.
They've posted the same broken English post 3 times in a row now despite nobody speaking to them.
If we acknowledge it will it stop? It's scaring me.
I feel like I'm being passive aggressively told to shut the fuck up because they've made up their mind.
https://linustechtips.com/topic/597661-power-supply/#findComment-7761371
It's a bit wasteful though... You're not going to be needing 750W either way. The quality difference is very minor.
https://linustechtips.com/topic/597661-power-supply/#findComment-7761376
