How to post hyperlinks?
Go to solution Solved by VeeTeePee,
Use the "link" button at the top of where you post?
Link
4 minutes ago, I am an SSD said:
I googled it and I tried
[url=http://pcpartpicker.com/parts/partlist/]Parts[/url]
But it didnt work
Just paste in the URL and it will do it for you. Example.
https://linustechtips.com
https://linustechtips.com/topic/596792-how-to-post-hyperlinks/#findComment-7751833
But it didnt work
Just copy and paste the URL into the box.
http://pcpartpicker.com/p/4fp4t6 I understand the question better now.
https://linustechtips.com/topic/596792-how-to-post-hyperlinks/#findComment-7751834
There should be an icon which looks like this:
Click on it and you can see the hyperlink popup.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/596792-how-to-post-hyperlinks/#findComment-7751840
Link
Thanks a lot
Test
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
https://linustechtips.com/topic/596792-how-to-post-hyperlinks/#findComment-7751845
35 minutes ago, I am an SSD said:
Thanks a lot
Test
or just paste the link in..
https://linustechtips.com/topic/596792-how-to-post-hyperlinks/#findComment-7751949
19 minutes ago, Starelementpoke said:
I think he wanted to do the thing where the link shows up as different text.
i hate that :P
https://linustechtips.com/topic/596792-how-to-post-hyperlinks/#findComment-7752012
This forum software doesn't support BBcode directly. You need to use buttons in editor. If you can't see button you need, press Cntrl+- few times.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/596792-how-to-post-hyperlinks/#findComment-7753552
