difference in preformacne between cpu's
Go to solution Solved by helping,
Checking email and youtube? No
Everything else, mmyeah.
would there be a big preformance between an ivy bridge celeron and a core i5?
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/59507-difference-in-preformacne-between-cpus/
what a silly question
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
Generally and almost always--yes.
i got a laptop and it appears the cpu is compatible so i was going to switch them, i mainly program and play diablo while away from my desktop
I would not try to switch the CPU on a laptop especially with that big of a gap, generally the laptop cooling is only barely sufficient for the CPU it comes with.
it appears there are other versions of my laptop with this cpu, i would imagine that they use the same cooling system
when they make a wafer of ivy bridge cpus the ones closest to the center and get turned into i3's i5's and i7's and sometimes extremes. celeron and Pentiums tend to be on the outside, thus lower end in performance
work it ᕙ༼ຈل͜ຈ༽ᕗ harder, make it (ง •̀_•́)ง better, do it ᕦ༼ຈل͜ຈ༽ᕤ faster, raise ur ヽ༼ຈل͜ຈ༽ノ donger
ᕙ༼ຈل͜ຈ༽ᕗ HARDER, BETTER, FASTER, DONGER! ᕙ༼ຈل͜ຈ༽ᕗ
What a troll question.  The guy clearly has a decent rig and he's asking a most basic question like that.. Bravo?
refering to your comment yes it was in a way test i just wanted to see how the members would reply to simple questions, i have been on to many forums where people are rude and ignorant and i can honestly say this is one of the best one's i have been on the members are quick to answer, 9/10 solving the issue and doing so in a nice polite manner
Interesting approach.  Never thought about testing the waters in a new forum like that.  I find this community to be an interesting one having been part of communities of different types.  I can say this much, it's a different bunch than the ones that hang out in the YT comments. :-P
@TechBenchTV
Ex-NCIX Tech Tips Producer.  Linus hates my scripts.
This is easily one of the best PC forums i have ever been on.
