Dual Monitor Mount and is it possible...?
Solved by EmeraldFlame,
1 hour ago, GER_T4IGA said:Jayztwocents has this vesa mount with a huge base. Would something like that work? I am sure you can find a link to that one on his channel somewhere.
He uses the Ergotech 1 over 3 stand: http://ergotechgroup.com/gaming.html
Really made for more than 2 monitors, but if you are willing to spend the money, you can reconfigure it to just hold 2 monitors. All of the dedicated 2 monitor mounts I know of use the desk clamp style mount.
