Hi need advice
Go to solution Solved by WoodenMarker,
First of all thanks for the help.
[Q]
If I want to add a water loop in the future .
Or I want to upgrade the rig in the future.
Both have 7 years warranty So I think it's a good buy
Someone offers something else?
I again mention they cost the same price in my country
The 860i Looks good .. But just look .. I have the case of the Corsair Carbide Air 540
Is quite hidden there .. So it does not matter Beauty
Both are overkill. A single 750w bronze would be plenty.
Fyi, you need to quote a post or tag a member or else they won't get a notification you replied to them.
I do think that 1000W is overkill for you needs, but is up tp you.
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/59338-hi-need-advice/#findComment-805224
If you're not expecting to add any major custom watercooling loops, out of those, considering you don't need that much wattage and the corsair is cheaper I'd go 860i. I prefer the AX860i cause they come with all black cables whereas the sleeving on the Seasonic aren't as nice.
Both are excellent. If one suits your build more then maybe consider that aswell.
https://linustechtips.com/topic/59338-hi-need-advice/#findComment-805226
I would go even lower and say, if you don't build a custom loop, you will have plenty of headroom for overclocks and a bigger SLI/Crossfire combo than that, with only a Corsair 760i.
Corsair Link may also be fun to play around with and the accessory shop from corsair is better (e.g. pre-sleeved cables). Man, i wish i had a corsair 760i instead of my seasonic G-S. 550W. :D
who cares...
https://linustechtips.com/topic/59338-hi-need-advice/#findComment-805239
They are both great power supplies I guess its up to which one matches your build the best, if you are into that kind of thing that is. If it doesn't matter to you what it looks like go for the more watts if you plan on adding some power hungry parts in there at some point.
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/59338-hi-need-advice/#findComment-805240
[Q]
https://linustechtips.com/topic/59338-hi-need-advice/#findComment-805243
[Q]
https://linustechtips.com/topic/59338-hi-need-advice/#findComment-805250
