qx6850 and 212 evo
Solved by paddy-stone,
OK, cool, hope it goes well for you... are you using the line method or pea just asking? I personally hate the pea method, line is more consistent with coverage IMO.
Anyway, about the speed stepping thing, I personally can't; see why anyone disables it, it's there to help preserve power and excess heat when it's not needed... yet your CPU can still go to your maximum clock when needed... I think you'll see BIG improvements in your idle clock temp and then when stress testing it shouldn't hit it so hard either I wouldn't think... use AIDA 64 for stress test.
