Case fans?
Telebubbies
Hey guys! I am in a bit of a pickle right now. I have a CoolerMaster mastercase pro 5. It has 3 fans. The fans has a 3 pin connector. On my motherboard, I can only find 1 3 pin connector. Can I connect the other 2 pins anywhere else?
Thanks in advance!
Thanks in advance!
Splitter, hub, controller, etc.  Most boards usually have at least a couple headers besides the cpu.  What model is the mobo?
Gigabyte z170
5 minutes ago, Telebubbies said:
Gigabyte z170
There are probably some more fan headers that you are overlooking.  I can't say for sure without knowing which specific board it is.
It is the Gigabyte GA-z170-HD3 DDR4
3 pin fans can plug into 4 pin headers, or 2 pin ones, of course in a 2 pin header they'd be going full speed all the time
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
 The third pin reports rpm but the speed can be controlled by two pins.
Can you please help me? On the motherboard, it says SYS_FAN 1,2 and 3. SYS_FAN 3 has 3 pins. That is what I am looking for. The other SYS_FAN's has 4 pins.
I have the CoolerMaster mastercase pro 5, so I have 3 fans with 3 pins...
You can plug 3pin fans into 4pin headers.
I tried but it does not work..
What do you mean by it doesn't work?
I got it to work. But now I have one case fan that cannot be connected.. There are 3 fan headers on the mobo and 2 are taken by the fan, and the third is taken for the coolermaster hyper 212x. Is there still a way to connect the third case fan?
There are 4 fans headers on your motherboard.
Oh! Thanks a lot!
the 212 fan(s) should be plugged into the white fan header labeled cpu fan, should be around the top of the board or below the cpu socket nearish the ram slots
desktop
HTPC
