Best Fans for HTPC
PokeCatz
I have the lian li c50 htpc case
http://www.lian-li.com/en/dt_portfolio/pc-c50/
what would be a good mix between silence, airflow and pressure
side note:
preferably noctua
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
Just now, PokeCatz said:
what do you want to put into it?
NF-P12 are a good choice. if they are too loud you can still use the adapter.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
The problem is I can't decide between p12 f12 and s12.
ok im giving you the specs:
p12: 1300 / 1100 / 900rpm , 92,3 / 78,5 / 63,4 m³/h , 19,8 / 16,9 / 12,6 dB , 1,68mmH2O
f12:  1500rpm , 93,4m³/h , 22,4dB , 2,61mmH2O
s12a:  1200rpm , 107,5m³/h , 17,8dB , 1,19mmH2O
the good thing about the p12 is the adapters. if you find it too noisy just use an adapter and it changes. same thing goes with temp problems.
So which would be best in my situation?
honestly the p12 there are a mix between static pressure and airflow. its exactly what you need.
If set on Noctua, use the S12 in all exhausts and the P12 or F12 for intakes.
