Would a Fan that fits on a FM2 socket fit on a fm2+ socket?
doctorraichu
2 minutes ago, doctorraichu said:
Please help
it should. Pretty much every AMD socket uses the same mounting hardware. (I used a FM2+ cooler on AM3+)
Breaking things 1 day at a time
26 minutes ago, doctorraichu said:
if you have an extra $10 get a Cooler Master Hyper 212 Evo. Most people on the forum will recommend this
17 minutes ago, doctorraichu said:
Please help
Wait why ask the question, what are you planning on doing? if you're going to spend money upgrade from FM2 to FM2+ don't bother man, unless your FM2 motherboard broke or something. were you going to buy a new one?
AM3+ stock coolers will also work
12 minutes ago, TubsAlwaysWIns said:
if you have an extra $10 get a Cooler Master Hyper 212 Evo. Everyone on the forum will recommend this
Don't put words in our mouth :P
I don't recommend the EVO because you can find coolers with the same performance for significantly less (although availability isn't as good since they're from smaller companies) or coolers with the same price and amazing performance (this one beats both the NH-U12S and the be quiet! Dark Rock Slim, which cost twice as much).
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
OK i will edit my post. I see your point. Just from what I hear there is an overwhelming majority of people that recommend it
Someone's gotta fight the fight. :)
Computer Specs:
