I'm trying to build my first PC. Like a good one that can run new games well. I have all of my parts picked out, except for the case. This may be a stretch, but I'm looking for a case that has good cable management and support for a 360mm rad. A comfortable budget for me is about 100 USD, but I could go up to 150. Any help would be great.
Thanks -Max
(P.S. The build has 2 GPU's so it needs to have room for those as well)
https://linustechtips.com/topic/590207-help-with-finding-a-case/
I'm quite happy with my fractal design define S.. If you don't have any need for an optical drive or too many hard drives(it can hold 2 2.5" and 2 3.5" drives but would require some type of modding for more), it offers great water cooling support and cable management options.
my work in progress
i5 6600k  //  16gb g.skill ddr4 3000  //  evga gtx 980
custom water loop
https://linustechtips.com/topic/590207-help-with-finding-a-case/#findComment-7682260
Okay the original poster literally put 2 criteria which was, supp. for 2 gpus and 360mm rad and that case has neither lol
https://linustechtips.com/topic/590207-help-with-finding-a-case/#findComment-7682287
fractal design r5
enthoo pro
mastercase 5
nzxt cases (idk nzxt cases well enough to recommend a specific one)
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/590207-help-with-finding-a-case/#findComment-7682298
Um.. actually it could hold 3 dual slot gpu's at virtually any length, and 2 360 rads..
my work in progress
custom water loop
https://linustechtips.com/topic/590207-help-with-finding-a-case/#findComment-7682300
fractal define r5 or S
https://linustechtips.com/topic/590207-help-with-finding-a-case/#findComment-7682327
There isn't a better Midtower watercooling case on the market than the Define S.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/590207-help-with-finding-a-case/#findComment-7682328
I also got the Define S and you get a lot for the price. And since it was made for watercooling, you don´t have to drill any holes in it. There are already holes to mount the pump and the resevoir.
This is what mine looks like (420mm Radiator on the top, 280mm in the front)
My next case will probably be a Caselabs SMA8 or whatever exists then. I could have gotten it for this build, but at some point you have to limit the budget yourself before it gets completely out of control. I already paid ~3500€ for my PC and I didn´t want to add another 500-1000€ just for the case.
https://linustechtips.com/topic/590207-help-with-finding-a-case/#findComment-7682401
