Corsair fans
BlueLightning
Can corsairs new fan line up (sp120s af120s and 140s) be powered by PWM?
Thread moved to Air Cooling.
Those are three pin fans, and therefore use voltage control, not PWM. Unless Corsair has PWM versions.
So if my mobo has pwm and i have other fans that do should i just go to bios setttings and set it to (auto) instead of (pwm mode)?
I guess just Auto. I've never mixed fan types together, as I use a separate fan controller for all of my fans.
There's a pwm version of one of the 120mm fans
GPU: GTX 980 Matrix            CPU: I5 4690k           Case: Cosair 750D         Motherboard: Maximus vii formula            Memory: 4x4 gb hyperx fury           Storage: samsung 840 evo 256gb
Dont' buy Corsair AF120 Quiet Edition !!! They aren't quiet :D Just to know tho..
If they aren't quiet, what fans are?
AF120 QE's are quiet tier in my book. http://www.silentpcreview.com/article1342-page9.html
On 5/2/2016 at 8:59 AM, SandroMK said:
I'm running them on 1500 rpm
Well there's your problem. Lower the rpm then.
