Is my monitor screwed?
aarondatechguy
Good Afternoon,
So I was going through my cupboard and came across this old LCD I have had for a while. The reason for not using it, is because it isn't very bright, which I believe is from the shadowing. See attached
I guess my question is, can this be fixed? Is should I just scrap it?
I am not scared to pull it apart if indeed I can fix it,
It is an Asus VW222U manufactured 2008
TYIA
Aaron
CPU: AMD R5-1600X @4.1 GHz/1.416v, GPU: EVGA GTX 1060 3gb, RAM: 2x8gb Crucial, Mobo: MSI B350 Pro Mate, CPU Cooler: Hyper 212 X, Case: Cooler Master Enforcer
I don't see anything wrong with it.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
its brighter towards the edges. maybe the picture doesn't do it justice.
I believe you can fix it yourself but iirc it's not very simple
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
Thanks for the link to the video. I missed that one.
So, i'm looking at backlight bleeding? Now the research for a fix begins.
Thanks for your help!!
I might be wrong, but it looks to me like it's just getting a bit old.  Since it has fluorescent bulbs inside that light up the screen, it'll get dimmer over time.  Usually after running a few minutes they get brighter as the bulbs warm up, but over the years they just get dimmer and dimmer, unfortunately.  I have an old Acer monitor from around the same time and it's starting to have the same issues.
yup thats backlight bleed
