Freesync for 1440p/390X
ThatsMyGamer
I am planning to build a mid-range ($900 plus OS, optical drive, mouse, and montitor) build using an AMD FX-8320 and an R9 390X. I'm planning on gaming in 1440p and was wondering if I would need a FreeSync monitor as the cheapest 144Hz model is $400. Any help?
Well, problem is a FX-8320 will bottleneck a R9 390X. Your going to need a CPU with a little more horse power.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
I plan to OC. Will this remove the bottleneck?
not that much... its better to upgrade
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Not really. Not enough anyway.
Would an 8350 be good?
3 minutes ago, Starelementpoke said:
It´s the 8320 but oced. No.
What about an AMD 9000 series processor. Same story?
Is the $900 the tower itself? Or does it include the price for the monitor, os, and dvd drive and such?
Yep.
Wo./ I'm not a magician
no.
Old Rig
7 minutes ago, Starelementpoke said:
It says nowhere that it´s not a bottleneck.
Most people never want to admit to bottlenecks. Especially in a new build.
The fact of the matter is that the 8320 came out in 2012.
If you want cheap, you can get a non-K Intel CPU and an H branded motherboard and still get +25% frame rates.
As for your question, you don't *need* freesync, although it's very nice to have. At your budget, I'd advise against it, unless you get a 1080p monitor (specifically the Nixeus Vue 24 inch 1080p Freesync [30Hz to 144Hz] monitor ~$250).
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
