It sounds like something that spins infrequently and then stops.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/587171-pc-wierd-buzzing-noise/#findComment-7649292
14 hours ago, AMG-Tech said:
Is the fan actually needed, is there adequate other airflow?
Well this is what the website says it looks pretty important to me. Would rather fix it because the noise isnt there always as i said it starts and stops randomly. Will unplug it if there is no solution to it.
https://linustechtips.com/topic/587171-pc-wierd-buzzing-noise/#findComment-7653253
