Looking for Air Cooler
Clanscorpia
Soooo, I finally got enough money for my PC, but Im not sure what cooler I want. I have $70CAD to spend on one and I'd like one that looks nice (Black metal), and performs as or almost as well as the Dark Rock 3. I was looking at the PH-TC12DX_BK and I liked the look but I've heard its loud. Is it possible to make it quieter or is there a better product?
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
hyper 212 evo + spray paint :D
what are you trying to cool?
-sigh- feeling like I'm being too negative lately
6600K OCed to 4.5GHz
AXIOM
mmm... dark rock 3 is pretty much my recommendation, though it cost slightly more
the quality and performance is worth it tho imo (im using DRP3, so i might be biased :P)
:/ I'd like to get a better mobo though so I can't buy such an expensive one.
AXIOM
there arent many air collers worth it other than the 212 evo, you also get some good ones at higher prices but the performances arent incredibly better
how bout a cryorig H7?
It's so ugly though, and it's loud :/
AXIOM
Cryorig isn't available in Canada
AXIOM
its not really loud, the fans that come with it are pretty good imo, you can always change for a better fan if you really care about the sound, also from most angles you only see the fan, which is black and it will not reduce performance to paint the top
and it probably wont cool your cpu properly with that OC
then i guess... you're out of the mainstream options lol
maybe someone will know a not so popular cooler that will fit your need :P
How would it handle it with a Noctua/be quiet! Fan?
AXIOM
assuming you're asking about hyper 212,
changing the fan is probably the worst price to performance thing you can do lol
it will increase the performance slightly but my best bet is it still wont cool your chip properly
just stay with stock fans, they're not that bad either
well you can get it if you want, but you might have to tune down the overclock to match the temps you want
I think I'll get the Phanteks :) Should be ordering tonight :D
AXIOM
Cryorig H7 or H5, if you can get Cryorig where you live. The H5 does a better job at cooling but if you can't afford US$46 or something like that then the H7 is better.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
Or you can just disregard my post. Doesn't Amazon US ship to Canada?
Edit:
Quote
I suppose that's an option too. I like some of their cases but not a huge "phan" of their coolers.
Edited by wcreek
The quote, the quote inside my head.
This is so far from the truth it's nauseating. Put an NH-D15 and a 212 EVO on the same 4790K, crank the voltage way up and see which cooler hangs in there while the other throttles out.
OP, Phanteks makes some good stuff. Nice choice.
Aerocool DS are the best fans you've never tried.
