My first NAS
Solved by ddbtkd456,
1 hour ago, Hulkbert said:So, should I try to build it with ~$100 usd for everything else or buy a prebuilt from wd?
The thing that you need to understand with nas and raids are that raids are better done with raid controllers which are $500 new...for a decent one (LSI). One top of that to do it correctly you need error correction memory which is pretty expensive (ECC Memory). To properly run freenas you would need 1gig per tb of space. My recommendation would be to get the WD prebuilt one if your not doing anything extensive.
