Hello everyone!
So I currently have the EK-KIT L240 (R2.0) https://www.ekwb.com/shop/ek-kit-l240-1
And I was wondering will there be any compatibility issues with this tubing?
http://www.watercoolinguk.co.uk/p/XSPC-38-ID-58-OD-High-Flex-2m-Retail-Coil-REDUV-ORANGE_28976.html
Cheers everyone!
https://linustechtips.com/topic/585146-ekwb-starter-kit-compatibility-issues/
it will work
1 minute ago, RekApuFF said:
Yeah I know it will work, but I'm talking as in contamination issues in the loop?
No contamination issues will stem solely from the use of this tube.  I've used XSPC and Primochill both with all other EK equipment(Rad,Pump,Res,Blocks).  Just make sure the loop is prepared correctly and you use acceptable fluid.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
Excellent thank you very much! :)
