i have the evga super nova g2 but looking for blue sleeved cables to match everything but not sure if the dark blue cables will go with the corsair blue fans since they are light blue and cant seem to find any light blue cables, anyone have any idea if there is any going about? thanks
https://linustechtips.com/topic/581958-sleeved-cables/
blue and light blue go great together
Well, now you're reading this, I might as well inspire you with a deep quote
If you fall, I'll be there
             - Floor
so inspiring, so deep, the feels ;-;  THE FEELS ;-;
Newer Build which I'm gonna buy when I haz moneyz
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£0.00)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (£25.98 @ Novatech)
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard  (£78.10 @ Amazon UK)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£0.00)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£29.76 @ Ebuyer)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£0.00)
Video Card: MSI Radeon R9 380 4GB Video Card  (£179.99 @ Amazon UK)
Case: Corsair 780T ATX Full Tower Case  (£149.99 @ Amazon UK)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For £0.00)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£59.00 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£24.99 @ Amazon UK)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard  (£184.99 @ Amazon UK)
Total: £803.77
somethings says '£0.00' because I already bought them
probably best remix out there
If I follow you, consider your self lucky, I rarely follow people and when I do it's either because
1) I look up to you
2)I like your picture
3) Or you have an epic ass rig (40 titan x's 9 6700k's clocked at 29GHz that is what I call a epic ass rig, but no one has that soo...)
https://linustechtips.com/topic/581958-sleeved-cables/#findComment-7598282
idk if this is the color blue you want but
http://www.performance-pcs.com/cablemod-basic-cable-extension-kit-8-6-pin-series-blue.html
http://www.performance-pcs.com/cablemod-basic-cable-extension-kit-8-6-pin-series-black-blue.html
https://linustechtips.com/topic/581958-sleeved-cables/#findComment-7598298
5 minutes ago, Totalschaden1997 said:
You can always spray-paint the fans
4 minutes ago, Aytex said:
yep thats the color :)
https://linustechtips.com/topic/581958-sleeved-cables/#findComment-7598307
