Evening everyone,
I'm getting ready to start doing stuff on YouTube, the only problem being I have blue switches... I'm looking at a membrane alternative to eliminate sound while gaming so I found the Nostromo. I can get it for $60 brand new, has anyone had any experiences with the Nostromo or can anyone off any alternatives? Thanks in advance.  ^_^                        razer-nostromo-gallery-1.png
Case = Bitfenix Prodigy, Motherboard = P8Z77 - I Deluxe, CPU = 3570k @ 4.2GHz, RAM = 2x 8GB G-Skill Ripjaws, GPU = Sapphire 7950 Boost Edition, Storage = 256GB Samsung 840 Pro.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/
I have had it and I loved it! I got so used to it that I eventually didn't even consider gaming on a keyboard whether i was recording or not. Its a little weird to get used to but once you do its great.
Awesome, thanks for the help. It looks like it will be interesting to begin with as I'm too used to Shift and Ctrl and the buttons on the Nostromo look pretty tiny.  :wacko:
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783394
Just get some 20$ membrane keyboard for gaming while streaming. Those things are really crappy and cost 3x of some keyboard you can use while streaming before going back to your blues ^^
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783398
One of the main reasons I was looking at this in the first place was space to be honest, I don't have much room on my desk and constantly moving keyboards around will get pretty tedious I think.  :wacko:
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783401
Well they make good use of space I guess ^^
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783490
I think those are rubbish, they cost a stupid amount. if you pay a bit more then you can get a mechanical keyboard, just get a logitech g105 or a g110. Hell i use a bloody alienware keyboard which was £5. It does its job and it does it well.
Listen if you care.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783500
I should have mentioned this is AUD and mechanical keyboards start at about 100, everything is a little more expensive unfortunately.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783503
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783507
http://www.amazon.com/Dell-H9Y23-SK-8165-Plug-N-Play-Multimedia/dp/B00632BACQ/ref=sr_1_4?ie=UTF8&qid=1379594678&sr=8-4&keywords=alienware+dell+keyboard
This is cheaper and has the standard stuff and media buttons. Ive tested it and it is robust and quiet.
Listen if you care.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783514
It will feel very weird as you thumb doesnt have a spacebar to rest on.
Listen if you care.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783517
Woot.com always have them for less than 60. I have one and it's cool but it's a small use case.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783519
Because I can get one brand new on Ebay for 35 do you think it would be worth it? It will be used alot I just don't want another keyboard occupying my desk if at all possible.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783530
well, let me put it this way.
Your thumb will have direct access to not only a space bar, but also an 8 way d-pad and simple little button too. what makes that fact better. you dont have to move your hand at all to be able to reach those 10 buttons (8 way d-pad) on just your thumb.
the palm rest is comfortable and your hand rests on it beautifully so you can game long hours and not worry about wrist cramping up.
the back line of buttons on the keypad are tilted forward making it easier to hit them with your fingers.
You can also program the scroll wheel to what ever key you want just like every thing else. but out of all the keys the scroll wheel is the trickiest to reach and you may actually need to move your hand to reach this key, and ONLY this key. every thing else is smooth.
im short, you can sit back relax and game comfortably with this awesome kit.
Is it over priced for what it is. Yeah, it could do with being $20 cheaper, but ive still been willing to buy two of these over a 9 month period at their full price.
Case: Fractal Design Arc Mini / Motherboard:GigaByte G1-Sniper-M5 / CPU: Intel 4670k / Ram: 16GB Corsair Vengeance LP 1600mhz / GPU: Asus GTX770 Direct CU 2GB / PSU: OCZ ZT650 / SSD: 2xSamsung 840 240GB / HDD: Seagate Barracuda 1TB / Cooler: Corsair H100i / Fans: 3x Corsair AF120 + 2 Corsair SP120 / Mouse: Corsair M65 / Keyboard: Cheap Crap/ Headset: Razer Kraken / Misk: 3DConnexion mouse / Flight stick: Cyborg F.L.Y 5
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-783803
Like I said its  a lot more comfortable then gaming on a fully keyboard and I loved it especially for games like Arma that has controls all over the place. right now I use the orbweaver and will never game on a full keyboard again
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-785382
Awesome thanks for the help, the only keyboard I was willing to look at was $30 and I managed to get a Nostromo brand new for $35 off Ebay so I decided to just take the plunge, thank you very much for the help.  ^_^
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-786315
Problem solved.
... :D
I had an Xbox 360 windows controller but it appears they are incredibly weak as dropping it twice from a desk has killed it.  :(
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-786318
Get the updated version based on the orbweaver or the orbweaver.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-786590
stay away from the old one with the orange thumb button
I've been using mine since 2006 or 2007 and I would never ever MMO without it never again will I contort my hands to hit shift/cntrl/alt and my abilities and with my movement mapped to the thumbstick I can dps or tank or heal on the move
when I played around a lot with sony vegas I made a special map for those functions and right now I have it set up for rome 2 total war.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-787199
Depends on the use case. I mean it works well with most games and the drivers are pretty good. The macros are pretty handy for RTS games and for some applications (Photoshop, Premier, Vegas) the build quality is pretty standard for Razer, pretty good in other words. The lighting is bright and it can open up a tone of options depending on how you use it. Hope this helps. But keep in mind, the Nostromo is discontinued so you may want to look at Razer's new series of macro keyboards, the Orbweaver and the Tartarus which Linus reviewed. http://www.youtube.com/watch?v=glC72mwjyN4 and http://www.youtube.com/watch?v=tQqudcggpsY
   Hail Sithis!
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-787213
Ill say that it depends on what games you want to play, for example i use my orbweaver for battlefield and i have JUST enough buttons to only use my mouse and the orbweaver. the nostromo has much less buttons and its an older gamepad with membrane switches(although you wanted that for less noise). i'd say that you look into the orbweaver stealth or the tartarus and make your choice out of that.
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-787218
Yeah I have the same problem with my Nostromo and some games where I need a lot of buttons. It is comfortable though which is a plus but the membrane switches and the small size is a downside for some people.
   Hail Sithis!
https://linustechtips.com/topic/57817-razer-nostromo-thoughts/#findComment-787221
