alright so I've found myself in need of a RS232  cable, but since computers don't have RS232 ports for some reason, I have to use a converter. Now I have some old USB-to-RS232 converter, but I'm not sure how to use it. I've tried connecting it to both devices but it seems like it really won't work this simply. There are some CDs that came with the purchase, years ago. It seems like drivers, but the drivers stop at Windows XP. As tried installing those, but I can't install them.
Also, the CD says  nothing about 64bit or 32bit operating systems support, I'm using Windows 8.1 64bit.
Is there any chances I'll get my old converter to work with Windows 8.1 64bit?
Should maybe all the manufacturers' converters work with the same drivers, since the protocols are defined by standards? Or does every manufacturer demand their own driver?
I don't understand these converters well enough, I know that RS232 is a serial interface, but aside from that I just don't know how this is supposed to work.
https://linustechtips.com/topic/577672-usb-to-rs232-converter-issues/
The USB converters are a pain if they have a poore driver. Have you tried compatibility mode?
Also all MoBos (even the gaming once) still have RS-232 but only as a header on the PCB. You should be able to finde a breakout cable for <5$.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
unless there are drivers for 64bit, your only option is to buy another one or find a PCIe card with the RS 232 port.
http://www.amazon.com/s/ref=nb_sb_noss/184-8952073-7334734?url=search-alias%3Daps&field-keywords=pcie+serial+card
what company manufactured it?  You may be able to find modern drivers for it, but I'm not sure.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
