Help me decide between 2 144HZ monitors with G-sync
Solved by NIC ROBERTOOO,
Assuming you want g-sync for newer games... There are a few other options. I'd also like to point out that the xb241H replaces the XB240H. Here are some Amazon links at least
24" G Sync Monitors:
AOC G2460PG http://www.amazon.com/AOC-G2460PG-24-Inch-LED-Lit-Monitor/dp/B00SIZ8QDM
BenQ XL2420G http://www.amazon.com/BenQ-G-SYNC-24-Inch-Monitor-XL2420G/dp/B00MUT6SLE
27" G Sync (1080p for your price point roughly)
Acer XB270H-G http://www.amazon.com/Acer-XB270H-Abprz-27-inch-Widescreen/dp/B00NUCRBCU
