Need Help / Suggestions for new build
Solved by BurblingBarbacoa,
This build is... Eh. To say the least.
- I don't really reccomend the 8300. Either step down to somthing like a i3 6100 or a Athlon X4 860K or step up to somthimg like a 8350 or a i5 6400.
- Motherboard is good. Obviously you will have to change it if you step out of the FX lineup.
- Get a dual channel kit of 8gb. It will still give you better preformance now and you will still have room for 16gb. Don't consider 32gb. There is a 99.9% chance that you will not need it.
- The V300 is miles better than a HDD but there are much better SSDs for the money. Maybe a SanDisk Ultra II or a 850 Evo. Either go up to 480gb/500gb or get a 1tb WD Blue. 120gb will run out quick.
- Don't even consider 960 sli. In fact I reccomend that you get a 380 instead and then upgrade to a higher end single card when you need to.
- That case is... Ok I guess. If you want something a tad better look at the NZXT S210W. However having said that, the Rosewill chassis will do the job for a budget oriented rig.
- Power supply looks fine. Maybe step down to a better, lower wattage supply if you take my no sli advice. Maybe a 80plus gold 650w. That will hand any high end card fine. If you continue to go for 960 sli then yea 750w is absolutley fine.
- 21.5" is pretty small. I consider 24" to be an absolute minimum and 27" to be the sweet spot. However, if that is big enough for you then go for it. Speaking of monitors; a single 380/960 will handle 1080p fine. No real need for an upgrade anytime soon.
- Peripherals? Sound?
Hope me I helped
Tell me what you think
EDIT: I know I am a hypocrite. I have 960sli and a v300 boot drive. Don't judge me
