Well I killed my r9 285 with static (be careful kids) I need a new GPU. I am looking at something in the 970 performance area for good 1080 gameplay. I have no real preference on the manufacturer and just care about power to cost. The Cheapest I can a 970 for is £230~ on ebay. However most 290(x)'s are going for £180~ on ebay. The reference 290s are know for getting super hot . So which to go for becuase with the 290 I could also get 8GB of ram over my current 4GB. So convince me either way.
https://linustechtips.com/topic/572895-970-vs-reference-290x/
reference 290's don't really have 8GB, they are all 4GB
get a Sapphire Tri-X, MSI Twin Frozr, XFX DD or don't  get it at all
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506058
Just now, beach_boy98 said:
With the ram thing I mean like system CPU ram.
okay,
unless you want to water cool don't get reference 290
it's not like it will be worse than your 285 or anything like that but spending like 5~10$ more to get a decent cooler on it is worth it
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506071
Ref. 290 then spend $20 on getting a better cooler for it.
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506076
I'd take the gtx 970, less power consumption, great overclocker, stays cool while overclocked (mine runs at about 71c in an M-atx case (coolermaster elite 130) and by the time 8GB becomes relevant in gaming, you'd need an upgrade anyway, so the 4GB is not really an issue.
Another thing to consider with the 290/290x - they were pretty good mining machines back in the day, so most of them are pretty much dead within a year or so.
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506089
1 hour ago, beach_boy98 said:
Ok I might go with one of those Corsair Hydro AIO adapters then.
Nice move, just make sure they're compatible.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506334
Yeah £40 extra isn't bad and it'll help.
How much would a 290x with a better cooler cost?
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506348
With you wanted the 8gb vram for the 290x the only option would be the Sapphire Vapor X edition R9 290x. I would like to give you some advice. Don't shop based on brand, if your primary concern is cost make your decision based what gives you the best price per performance.
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506355
Again 8GB of System memory.
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506358
Less but it still won't be as good as an AIO.
True. Just a suggestion. Give the 290x a good OC and it'll be golden.
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506361
I have a 290x with a h75 and the temps are decent at stock clocks (30c idling and 50c underload with fans at minimum speeds) while OCed with 1100mhz at +100mV and +50% power (max, I still haven't installed my VRM heatsinks for this card...so before I up the clocks anymore gotta install em) it idles at 35c and underload, it goes to 70c max
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7506370
I doubt many miners are just now selling their GPUs, and a 290X is much less likely to be a mining card than a 290. For some reason the 290 was way more popular.
Power consumption? Are we living in Africa? Paying $2 more a year is fine with me. 290X overclocks well, and when it hits the 1200MHz range (if it does) it's up there with a 980.
i7 6700K @ Stock (Yes I know) ~~~ Corsair H80i GT ~~~ GIGABYTE G1 Gaming Z170X Gaming 7 ~~~ G. Skill Ripjaws V 2x8GB DDR4-2800 ~~~ EVGA ACX 3.0 GTX 1080 SC @ 2GHz ~~~ EVGA P2 850W 80+ Platinum ~~~ Samsung 850 EVO 500GB ~~~ Crucial MX200 250GB ~~~ Crucial M500 240GB ~~~ Phanteks Enthoo Luxe
https://linustechtips.com/topic/572895-970-vs-reference-290x/#findComment-7508631
