I bought a CoolerMaster Hyper 212 EVO in 2011, but i never installed it. never even opened it. This week ill be rebuilding my computer and iv decided to add it to my 6600k CPU as it does not come with a CPU cooler.
The Hyper 212 EVO comes with its own thermal paste right? Will it still be okay to use? Iv never even opened the CPU coolerbox so nothing inside is touched....
Can i use or not? If i cant, what themal paste should i go buy?
https://linustechtips.com/topic/572748-does-thermal-paste-expire/
Doesn't really expire. Usually it dries way before its expiration date hits. That being said, you can get a better tube of paste for like $8. Cryorig sells some good thermal paste.
get some MX-4 , it lasts over 8 years
your 212 evo paste is probably too old to use effectively
I would get new thermal paste for it. The stuff that comes on that cooler is pretty horrible. When i still had an h212, i dropped 10c from just a better thermal paste.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
as an example, I was taking a cpu off of a PC from 2000ish and the paste was basically powder
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
well, being used and being in a tube is quite different lol
if its applied onto the cooler then i suggest replacing it, if its in a tube and you dont mind the marginally better temps the other thermal paste offers
i suppose you can use it, its just not worth the hassle to rush out and buy a new thermal paste for few celcius lol
-sigh- feeling like I'm being too negative lately
You should be good, Worst thing that will happen is your temps wont be where you want them
Pls Follow your own posts!      Chief Engineer for my School Studio, Own my own Home Studio also. I also do requests for Remixing songs too :D Storage Server: Mobo: Supermicro X8SIA-F Case: Some Supermicro 1U case Drives: 3x 2TB Seagate Barracuda 7200 RPM drives, 1x 3TB Seagate Barracuda 7200 RPM CPU: Intel Xeon X3430 2.4GHz Ram: 2x Kingston ECC 2GB sticks
Might as well get some new Thermal Paste then. its relatively cheap and the parts dont come untill thursday so might as well :)
Will a 212 EVO from 2011 still work with a new Skylake 6600k on a Gigabyte Z170 HD3 mobo?
Should, if it fits socket 1155 then it should fit skylake
Just looked at the box, it said it supports 1155. phew im lucky I get to use it :D
Is http://www.pbtech.co.nz/index.php?z=p&p=FANDPC2013&name=DEEPCOOL-THP-Z3-Z3-total-weight-6.5gram-Thermal-co
a good Thermal Paste?
The closest PC shop only has 4 types of Thermal Paste
http://www.pbtech.co.nz/index.php?p=search&sf=Thermal+Paste
Which one is best?
Anything really is decent thermal paste.. I personally use a $1 tube of it. I bought like 5 huge tubes of it for like $3
if you go in store they should have some arctic silver 5 otherwise just ask they staff are normally really good
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
There's minor differences between pastes. And while in sealed tube, they don't really dry up. Its like glue or toothpaste. It would take 10+ years for something to happen.
212 has multi-mount bracket which is compatible for all 115x sockets. Use middle holes.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Thanks, I'm actually really worried about putting the CPU cooler on lol
