Is this going to be a problem?
Go to solution Solved by Woose1,
2 minutes ago, tikker said:
I know you said there's no other way of mounting it, but as I've never seen this before, are you absolutely sure you're mounting it correctly?
At around 7:50 it looks to me you should rotate your backplate 90 degrees (got from your other topics that you have the Dark Rock Pro 3). Otherwise yeah, grind the screw down.
HAHA now i fell fucking stupid, you are right it needs to be rotated 90 degrees. thanks for saving me! :D
are you sure you are using the right mounting mechanism?
get a different cooler or grind the screw down
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
3 minutes ago, Woose1 said:
There is no other way of mounting the backplate.
and i cant get a new one will take to long.
Just now, Woose1 said:
was thinking of doing that will i need to take it out first you think?
if you are careful enough then you can getaway without taking it out
if you not sure, then take it out
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
15 minutes ago, Woose1 said:
Is it posibel to drill out an indentation in the back plate will that work to?
yes
that's the first think I asked... are you sure you're mounting it the right way?
Glad I could help :D
whoopsy, did the same mistake on mine... but it works fine...
I guess i have to reseat it within the next few days...
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
was about to just mount it like that but it seemd a bit wierd. so i saved my self from the hasel of reseating it.
jep good move :) but it isn't a problem the other way round, temps were fine
- Ryzen Build -
2x Dell UP2516D
