Problem found?
Go to solution Solved by Murasaki,
17 hours ago, PhoenixArising said:
To this point, I suggest you just reinstall. The bloody thing is a mess shouting one problem after another..
3 minutes ago, ModuleLFS said:
@PhoenixArising Try this http://www.thewindowsclub.com/error-code-0x8024001e-this-application-wasnt-installed
This method will most likely wipe out updated and will force it to re-update everything. Lets say its it unclogs windows update's drain.
Alright.. I will try it out
https://linustechtips.com/topic/569616-problem-found/page/3/#findComment-7529892
@ModuleLFS
This was in the log again after I restarted and the tower also hung again...
Log Name:      System
Source:        User32
Date:          4/1/2016 4:21:49 PM
Event ID:      1074
Task Category: None
Level:         Information
Keywords:      Classic
User:          DESKTOP-33S5UVJ\Taylor
Computer:      DESKTOP-33S5UVJ
Description:
The process C:\Windows\System32\RuntimeBroker.exe (DESKTOP-33S5UVJ) has initiated the restart of computer DESKTOP-33S5UVJ on behalf of user DESKTOP-33S5UVJ\Taylor for the following reason: Other (Unplanned)
 Reason Code: 0x0
 Shutdown Type: restart
 Comment:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="User32" Guid="{b0aa8734-56f7-41cc-b2f4-de228e98b946}" EventSourceName="User32" />
    <EventID Qualifiers="32768">1074</EventID>
    <Version>0</Version>
    <Level>4</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8080000000000000</Keywords>
    <TimeCreated SystemTime="2016-04-01T20:21:49.011423500Z" />
    <EventRecordID>11563</EventRecordID>
    <Correlation />
    <Execution ProcessID="552" ThreadID="960" />
    <Channel>System</Channel>
    <Computer>DESKTOP-33S5UVJ</Computer>
    <Security UserID="S-1-5-21-557467918-1737020828-2909610138-1001" />
  </System>
  <EventData>
    <Data Name="param1">C:\Windows\System32\RuntimeBroker.exe (DESKTOP-33S5UVJ)</Data>
    <Data Name="param2">DESKTOP-33S5UVJ</Data>
    <Data Name="param3">Other (Unplanned)</Data>
    <Data Name="param4">0x0</Data>
    <Data Name="param5">restart</Data>
    <Data Name="param6">
    </Data>
    <Data Name="param7">DESKTOP-33S5UVJ\Taylor</Data>
  </EventData>
</Event>
Also checked for windows updates and the update service did not find any new updates... Also when I went through the event log, I found that there was an event that said the last shutdown success status was true which was like a min after I turned off the pc tower and rebooted it since it hung when I had the pc restart.
Log Name:      System
Source:        Microsoft-Windows-Kernel-Boot
Date:          4/1/2016 4:22:34 PM
Event ID:      20
Task Category: None
Level:         Information
Keywords:
User:          SYSTEM
Description:
The last shutdown's success status was true. The last boot's success status was true.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Boot" Guid="{15CA44FF-4D7A-4BAA-BBA5-0998955E531E}" />
    <EventID>20</EventID>
    <Level>4</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000000</Keywords>
    <TimeCreated SystemTime="2016-04-01T20:22:34.662388900Z" />
    <EventRecordID>11575</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="LastShutdownGood">true</Data>
    <Data Name="LastBootGood">true</Data>
  </EventData>
</Event>
@ModuleLFS
I checked the softwaredistribution log and it shows that windows update successfully found 12 updates yet when I check for updates it says my current device is still up to date.
Restarted my pc again and the tower fans/power leds stayed on. Checked the event log after and found this:
Log Name:      System
Source:        Service Control Manager
Date:          4/1/2016 5:09:32 PM
Event ID:      7026
Task Category: None
Level:         Information
Keywords:      Classic
User:          N/A
Description:
The following boot-start or system-start driver(s) did not load:
cdrom
dam
Event Xml:
  <System>
    <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
    <EventID Qualifiers="49152">7026</EventID>
    <Level>4</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2016-04-01T21:09:32.953507700Z" />
    <EventRecordID>11647</EventRecordID>
    <Correlation />
    <Execution ProcessID="724" ThreadID="728" />
    <Security />
  </System>
  <EventData>
cdrom
dam</Data>
  </EventData>
</Event>
https://linustechtips.com/topic/569616-problem-found/page/3/#findComment-7530209
@ModuleLFS After spending 7 hours chatting with microsoft tech support, I think I found a solution. Just waiting on the file to download.
https://linustechtips.com/topic/569616-problem-found/page/3/#findComment-7533602
