Problem found?
Go to solution Solved by Murasaki,
17 hours ago, PhoenixArising said:
To this point, I suggest you just reinstall. The bloody thing is a mess shouting one problem after another..
2 minutes ago, ModuleLFS said:
sc config "OneSyncSvc_Session1" start= disabled
sc stop "OneSyncSvc_Session1"
Also make sure your command prompt is elevated (administrator) else it will just yell with access denied.
It's spewing out "the parameter is incorrect" error messages at me
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7519426
1 minute ago, PhoenixArising said:
http://imgur.com/j0c3rcd
That correct?
I'd say thats one step ahead, try stopping OneSyncSvc_Session1 again, if it doesnt work, I have a backup plan, but test it out first if you can shutdown properly.
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7519516
Just now, PhoenixArising said:
Was able to shut down successfully
Awesome.
Though if it happens again, another alternative is tinkering with the registry.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\OneSyncSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\OneSyncSvc_Session1
Start value set to 4
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7519610
When I shut down again last night the tower hung. I looked into the event log and there were no errors right before shutdown.
There was this however in the admin events section which occurred right before shutdown:
Log Name:      Microsoft-Windows-Kernel-EventTracing/Admin
Source:        Microsoft-Windows-Kernel-EventTracing
Date:          3/30/2016 8:05:56 PM
Event ID:      4
Task Category: Logging
Level:         Warning
Keywords:      Session
User:          SYSTEM
Computer:      DESKTOP-33S5UVJ
Description:
The maximum file size for session "ReadyBoot" has been reached. As a result, events might be lost (not logged) to file "C:\Windows\Prefetch\ReadyBoot\ReadyBoot.etl". The maximum files size is currently set to 20971520 bytes.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{B675EC37-BDB6-4648-BC92-F3FDC74D3CA2}" />
    <EventID>4</EventID>
    <Version>0</Version>
    <Level>3</Level>
    <Task>1</Task>
    <Opcode>10</Opcode>
    <Keywords>0x8000000000000010</Keywords>
    <TimeCreated SystemTime="2016-03-31T00:05:56.910247700Z" />
    <EventRecordID>152</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="140" />
    <Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
    <Computer>DESKTOP-33S5UVJ</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="SessionName">ReadyBoot</Data>
    <Data Name="FileName">C:\Windows\Prefetch\ReadyBoot\ReadyBoot.etl</Data>
    <Data Name="ErrorCode">3221225864</Data>
    <Data Name="LoggingMode">276824064</Data>
    <Data Name="MaxFileSize">20971520</Data>
  </EventData>
</Event>
@ModuleLFS I also entered safe mode to check my drivers and there was still a yellow triangle next to system firmware
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7521868
@ModuleLFS Just ran a systemfile checker through the admin command prompt and it managed to find a bunch of corrupted files. Don't know if that was causing it or not
Hmmm, well you'll have to check if it did anything.
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7527354
@ModuleLFS When I was in the bios I noticed that the fastboot option was enabled even though I disabled it weeks ago. This is like the third time that I have noticed some of the bios options resetting.
Also do you know what this is?
Log Name:      System
Source:        User32
Date:          3/31/2016 8:00:34 PM
Event ID:      1074
Task Category: None
Level:         Information
Keywords:      Classic
User:          DESKTOP-33S5UVJ\Taylor
Description:
The process C:\Windows\System32\RuntimeBroker.exe (DESKTOP-33S5UVJ) has initiated the power off of computer DESKTOP-33S5UVJ on behalf of user DESKTOP-33S5UVJ\Taylor for the following reason: Other (Unplanned)
 Reason Code: 0x0
 Shutdown Type: power off
 Comment:
Event Xml:
  <System>
    <Provider Name="User32" Guid="{b0aa8734-56f7-41cc-b2f4-de228e98b946}" EventSourceName="User32" />
    <EventID Qualifiers="32768">1074</EventID>
    <Level>4</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8080000000000000</Keywords>
    <TimeCreated SystemTime="2016-04-01T00:00:34.883658900Z" />
    <EventRecordID>11197</EventRecordID>
    <Correlation />
    <Execution ProcessID="552" ThreadID="688" />
    <Channel>System</Channel>
    <Security UserID="S-1-5-21-557467918-1737020828-2909610138-1001" />
  </System>
  <EventData>
    <Data Name="param1">C:\Windows\System32\RuntimeBroker.exe (DESKTOP-33S5UVJ)</Data>
    <Data Name="param2">DESKTOP-33S5UVJ</Data>
    <Data Name="param3">Other (Unplanned)</Data>
    <Data Name="param4">0x0</Data>
    <Data Name="param5">power off</Data>
    <Data Name="param6">
    </Data>
    <Data Name="param7">DESKTOP-33S5UVJ\Taylor</Data>
  </EventData>
</Event>
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7527379
No clue... I left the update alone for like 3 hours and it was froze at configuring settings... Is there a way to check specifically how it failed?
Event viewer is your best friend.
I'm hoping if it updates it might fix those damn problems.
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7529797
Log Name:      System
Source:        Microsoft-Windows-WindowsUpdateClient
Date:          3/13/2016 8:03:36 PM
Event ID:      20
Task Category: Windows Update Agent
Level:         Error
Keywords:      Failure,Installation
User:          SYSTEM
Description:
Installation Failure: Windows failed to install the following update with error 0x8024001E: Upgrade to Windows 10 Home, version 1511, 10586.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-WindowsUpdateClient" Guid="{945A8954-C147-4ACD-923F-40C45405A658}" />
    <EventID>20</EventID>
    <Version>1</Version>
    <Level>2</Level>
    <Task>1</Task>
    <Opcode>13</Opcode>
    <Keywords>0x8000000000000028</Keywords>
    <TimeCreated SystemTime="2016-03-14T00:03:36.563123900Z" />
    <EventRecordID>7384</EventRecordID>
    <Correlation />
    <Execution ProcessID="960" ThreadID="7272" />
  </System>
  <EventData>
    <Data Name="errorCode">0x8024001e</Data>
    <Data Name="updateTitle">Upgrade to Windows 10 Home, version 1511, 10586</Data>
    <Data Name="updateGuid">{5168068B-610F-4AC5-B8BB-8FDCC1D11A10}</Data>
    <Data Name="updateRevisionNumber">201</Data>
    <Data Name="serviceGuid">{9482F4B4-E343-43B6-B170-9A65BC822C77}</Data>
  </EventData>
</Event>
Log Name:      System
Event ID:      20
Level:         Error
User:          SYSTEM
Description:
Installation Failure: Windows failed to install the following update with error 0x8024001E: .
Event Xml:
  <System>
    <Level>2</Level>
    <Task>1</Task>
    <Opcode>13</Opcode>
    <TimeCreated SystemTime="2016-03-14T00:03:36.563125100Z" />
    <EventRecordID>7385</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    </Data>
    <Data Name="updateGuid">{169F31B4-6C6E-43B2-B496-6D9D6CA37182}</Data>
    <Data Name="updateRevisionNumber">1</Data>
    <Data Name="serviceGuid">{855E8A7C-ECB4-4CA3-B045-1DFA50104289}</Data>
  </EventData>
</Event>
@ModuleLFS
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7529802
@PhoenixArising Try this http://www.thewindowsclub.com/error-code-0x8024001e-this-application-wasnt-installed
This method will most likely wipe out updates and will force it to re-update everything. Lets say it unclogs windows update's drain.
https://linustechtips.com/topic/569616-problem-found/page/2/#findComment-7529868
