Best silent case that isn't a H440 or a define R5
Bolodin
Hey everyone,
does anyone know a Desktop Case that is silent, yet isn't either an NZXT H440 or a Fractal Design Define R5. My budget is around 100$/€. Please help, i have had an eye on the be quiet! Silent Base 600, but i heard that it isn't even that silent. Thanks.
1 minute ago, Bolodin said:
Hey everyone,
nanoxia deep silence
Most cases can be "silent" with quiet fans at low RPM's.
Phanteks Eclipse P400S.
I used to be quite active here.
nanoxia deep silence 6
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
Just dont make the same mistake as I did when I bough CoolerMaster Silencio.
And if you have loud HDD there is no case that can isolate the noise and vibration.
Fractal Design Define S is pretty good, its a Define R5 without the optical drives and some other features
31 minutes ago, Bolodin said:
Hey everyone,
The silenco series from cooler master is great
|| CPU: I7 6950X @4.6 (1.35V) || Cooler: CUSTOM EK LOOP || Motherboard: ASUS RAMPAGE V EDITION 10
|| GPU: 2x Vega 64 Strix OC @1762 / 1100 MHz || Memory: 16GB G.Skill Royal RGB 3200 Mhz ||
HDD: Segate Barracuda 3TB || SSD: Samsung 970 Evo 512 GB || PSU: Corsair HX 1200 W || Case: Fractal Design Define R6 Gunmetal || Fans: Corsair HD120 (x4) / BeQuiet Silent Wings 3 (x4) || Monitor: ACER XF27HU ||
Second Monitor: BENQ RL2455HM || Mouse: Logitech G502 Pretus Core || Keyboard: Logitech G810 Orion Spectrum || Headphones: Sennheiser IE80 ||
        Buildlog expirience swapping to x99:
I got Silencio 452 and its ridiculous that it actually went to production . Front dust filters useless since air doesnt flow there at all, bottom (PSU) air intake way too small and restrictive, zero room for cable management. It feels like they used some $5 case and mounted sound dampening meterials on side panels.
Not to mention that both fans that came with case have terrible clicking noise.
2 hours ago, Bolodin said:
Hey everyone,
The case itself doesn't make noise so I'm not sure who told you the Base 600 isn't quiet, but with quiet hardware in there it'll dampen the remaining CPU cooler noise or HDD nosie, etc. It's a very quiet case. Watch the HardwareCanucks review:
https://www.youtube.com/watch?v=cmPhd6guJKI
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
