So I just unpacked my brand new Audio Technica ATH-M50X headphones that I purchased for around $120, and when I plugged them into the headphone jack on my computer with one of the cables that came with the headphones, the audio quality didn't sound nearly as good as I expected. It sounded quieter than my old $50 Sony headphones from Walmart and even a bit muffled. I am shocked given all of the rave reviews of these headphones. Am I doing something wrong?
Current Rig: Intel Xeon E3-1231 V3, ASRock H97 Pro4 ATX mobo, 8GB 1600 MHz G.Skill Ripjaws, GTX 970, Corsair 550W, Kingston 120GB SSD & WD Black 1TB HDD, NZXT H440 Case.
https://linustechtips.com/topic/568102-ath-m50x-problem/
yeah, youre using onboard audio
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459726
Have you tested it on your phone/different PC aswell?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459729
get a dac/amp and it'll improve the sound by a huge amount.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459752
Ahh, the quality sounds much better when I plug it into my Nexus. It must be the computer audio.
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459770
I have a Focusrite Solo compact interface. Does that suffice.
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459776
yeah, you should reinstall your drivers and use the rear ports on the motherboard and not front.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459783
yes it does :) hook it up to that, not your motherboard audio
Old Rig
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459790
When I plug the headphones into the jack on my interface, I hear no computer audio. I know the jack is working because when I turn live monitoring of my mic on I can hear my mic through my headphones, but when I turn it off, I hear no audio coming from my computer. Is an additional connection from the interface to my PC required besides the USB connection already established?
https://linustechtips.com/topic/568102-ath-m50x-problem/#findComment-7459808
