It's 3100MHz RAM though
Desktop: Intel i5-3570K (stock) | Asus Sabertooth Z77 | G.Skill RipJaw 16GB 1600MHz | Samsung 840 120GB | EVGA GTX 680 SC+ 2GB | Fractal Design R4 | Windows 8 Pro (soon to have dual boot Mac OS X)
Retina Macbook Pro : Intel i7-3840QM | 16GB 1600 MHz | 256GB SSD | Nvidia GT 650M 1GB | Mac OS X 10.8.5
https://linustechtips.com/topic/56789-newegg-pricing-problems/#findComment-767518
Look at frequency man, it's understandable.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/56789-newegg-pricing-problems/#findComment-767531
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/56789-newegg-pricing-problems/#findComment-767546
I want someone to mate this RAM to an APU NOW!
Titan iGPU?!?!?!?
https://linustechtips.com/topic/56789-newegg-pricing-problems/#findComment-767553
I did a little researching and found THIS:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820211780 This is 2800mhz A-data RAM and it's $383.49. CAD
It shouldn't cost $716.50 more dollars for a 300mhz increase, though.
https://linustechtips.com/topic/56789-newegg-pricing-problems/#findComment-767580
it shouldnt cost 400$ for 3MB cache more (3930k vs 3970x).
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
https://linustechtips.com/topic/56789-newegg-pricing-problems/#findComment-767597
thats a bit different although, i do agree.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/56789-newegg-pricing-problems/#findComment-767636
