Budget Room audio system
fos1x
I need a 2 channel speaker with separate small Amplifier have control of Bass&Treble and ~ 20-30watt output per speaker
the speaker must be solid boxy looking not some standing plastic bar easy to falloff
and around 50-70$ dollar
thank for help and reading!
So you need 2 speakers with the following features:
20-30 watts of RMS handling power
"Box style" look
and a 2 channel amp with the following features:
Bass and Treble control
20-30 watts of RMS output power
And you want all of this for $50-$70 USD?
If this is the case, this is the best I can come up with (includes speaker wire as well)
http://amzn.com/w/2V97Z5JC04CSP
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
"Box style" look
it can be done
http://www.amazon.com/Lepai-LP-168HA-40-Watt-Amplifier-Output/dp/B0070Z87YO/ref=sr_1_3?ie=UTF8&qid=1457943673&sr=8-3&keywords=amplifier+lepai
http://www.amazon.com/Micca-MB42-Bookshelf-Speakers-Tweeter/dp/B009IUIV4A/ref=sr_1_3?s=electronics&ie=UTF8&qid=1457943512&sr=1-3&keywords=micca
almost.
Just now, JefferyD90 said:
Who said it couldn't be done?
your post tone was similar to that
My post tone?!?  I didn't include any emotes so there was 0 tone.  It was a legitimate question followed by a wish list suggestion.
yeah, wish list doesn't work by the way
Works now, I forgot to set it to public
