Corsair Obsidian 750D - Airflow Edition Fan Setup?
RoKa
Hey guys,
Im planning on buying the  Corsair Obsidian 750D airflow edition. And I was wondering what setup is best to use. I was thinking about 2 intakes on the top and front and 1 in the back. To create possitive pressure and force more dust out.
But on every setup ive seen it was 2 intakes at the front and 2 outtakes at the top and 1 at the back.
Example of the 2nd case:
So can someone please tell me the pros and cons of what im thinking? :)
Thanks in advance!
Kind Regards,
Roman
That forces more dust in.
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
Use the one in picture thats a balanced setup
The one on the picture or what Im talking of? I mean the case has an awesome magnetic filter ontop. :P
What your talking about. Use the setup in the picture
I thought positive air pressure forced more dust out of the case.
The more intake the more dust. Its simple your bringing more air in. Hot air also expands so you wanna get rid of the hot air more effectively so you can bring new cool air in.
But bringing in air from the top and front both goes through a filter and that fresh new air pushes out the existing hot air which also gets pulled out by one fan at the back.
You're actually wrong for the most part except for your comment about hot air http://forums.anandtech.com/showthread.php?t=705389 negative pressure creates a vacuum affect so you bring in more unfiltered air.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
More air coming in takes in more dust, yes. However, if you have your intakes filtered it will filter the dust out. So if you have positive pressure by have more airflow through filters on the intakes and less airflow as exhaust, you will keep dust down because the 'excess' air that the exhaust fans can't move will go out of any gaps.
But back on topic. For that case, I would just have the two intake fans on the front and one rear.
If you wanted to stay true to the image you posted, the two on the front should be made to run at a slightly higher rpm than the exaust. This will maintain positive pressure in your case
EVE (My Gaming Build)
Motherboard: Asus Maximus VII Ranger - CPU: Intel i5 4690k @ Stock Speeds - Cooling: Phanteks TC-12DX - PSU: Corsair RM750 - GPU: MSI GTX 1070 - Storage: 1x 120gb Samsung 830 Evo SSD (OS Drive) | 1x 120gb Hyperx 3k SSD (Audio Editing) | 1x 480gb Sandisk Ultra II SSD (Games) | 1x 1TB Hard Drive (Mass Storage) - Case: NZXT Phantom 530 - Misc: NZXT Hue RGB LED and controller
You asked for our opinions and you're not taking them in. I'm trying to help you. Negative air flow remove hot pockets in you're system. There is going to be dust anyway. Its impossible to not have dust. I recommend you read this http://www.tomshardware.com/forum/238184-31-case-airflow-positive-negative-pressure
Yeah I was trying to explain that I wanted to change what's in the picture. To make the top exhaust into a intake, because this case has a sexy magnetic filter there.
Im really doubting my English atm because I don't have the feeling people understand my initial post. xD
PS: I'm Dutch.
There will always be dust, but there will be considerably LESS dust.
Im trying to create positive pressure by turning around the fans in the picture at the top of the case.
Quote
PS: I'm Dutch.
PS: I'm Dutch.
Oh i see. Well, gerenally hot air rises and cool air moves in its place. If you put intakes on the top, any heat that rises will get forced back down to your components. The dust filter at the top is mainly for stopping dust falling into your system. Generally, intakes on top is a big 'no-no'
Ah ok, just one more thing to take into consideration.
If you force air from the top and the front. Doesnt the front intakes push the hot air out?
Epic drawn picture explaining what Im thinking:
Edit: Omfg the forum makes the picture appearing 10x cooler xD
Just told me that what you say about heat isnt relevant.
It WILL work having intakes on the top, but it's just not done very often. it'll probably be slightly less efficient at dispersing the heat out of your case, that's why people don't do it. Front/bottom intake and top/rear exhaust is the tried and true method of air cooling. People prefer it for a reason I guess.
Ah ok, I guess it just boils down to how my PC performs/looks like after a while. I just find it a waste not to use the top as a intake because it has a awesome filter which is hyped up everywhere. Otherwise I might as well buy the Graphite Series 760T from Corsair, which I wanted in the first place. But decided to change it to the case mentioned above because of the proper top intake/outtake with filter. Im planning on adding watercooling for the processor so I will have a radiator at the top. Im just not really 100% what to do at this point. :S
Well buy it and just try it and monitor your temps. The worst thing that will happen is your temperatures will creep up slowly. If it does get a bit too hot, take the fans out or just flip them for exhaust and monitor your temps again. If it's better, keep it like that. If you're having a radiator on top eventually, you should be having that as exhaust anyway.
http://www.corsair.com/en/hydro-series-h115i-280mm-extreme-performance-liquid-cpu-cooler
Im planning on buying this one.
What's the reason I must use it as an exhaust? Instead of an intake. I mean, the air from the radiator gets pushed and pulled out of the case really quickly.
Again, it's not that you "MUST" use it as an exhaust, but as well as hot air rising, you will also be throwing the heat from your radiator back into your case. It's all theory so take it with a grain of salt.
I've attached a picture I've found online and added airflow arrows. I've seen this method with watercooling setups. I know it's not an AIO, but you get the idea.
56e44cea8ff7c_airflowidea.png.3bb6e3325b
[not my image, google images]
REMEMBER, it's not neccessarily the amount of fans that dictates air pressure. It's airflow and RPM you need to consider. So if you have larger fans at the front running at a higher rpm than the smaller ones as exhaust, you can still maintain positive air pressure even if you have 1 or 2 more exhaust fans than intake.
[picture]
Ah ok, thanks for your time. :)
This has answered my question better than the videos I have watched. (gosh darnit Linus)
Ill be taking all this in consideration when building my pc.
Thanks again,
Roman
Give this a watch, it does explain it very well
