Problem! CPU compatibility
Solved by ApolloX75,
2 minutes ago, don paul herman pagtama said:well, im struggling with choosing those 2. should i go for the faster cpu but more money or fast cpu for low price?
Since you only have an H97 motherboard you might as well go with the in-between option which is the plain i7 4790 non-K. You don't have the benefit of overclocking thanks to the limitations of H97 boards, so why waste the money on a K sku CPU.
Unless of course you plan on getting a Z97 board later and overclocking. That's one reason I suppose.
Edit: The reason a Skylake CPU (6600 and 6700 for instance) won't work on your H97 motherboard is that they are a different socket design: LGA 1151. Haswell boards and CPUs (4790, etc) are LGA 1150.
