Hum, Overclocking Memory is highly non recommended.
What speed is it running at :
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382502
TFW your memory doesn't even support XMP
Only Rig: CPU I7 6700K @ 4.7Ghz | MB Gigabyte GA-Z170-HD3P | GPU GTX 1080 TI Founders Edition With Hybrid Cooler Installed | RAM G.Skill NT Series 16GB DDR4 @ 2600Mhz | CPU Heatsink Corsair H100i V2 | SSD Kingston V300 Series 240GB | SSD Generic 120GB M.2| HDD Western Digital Blue 750GB (10 years old) | HDD Seagate Barracuda 500GB | HDD Seagate Barracuda 2TB | PSU Corsair CSM 750W 80+ Gold | Case NZXT S340 Elite | Monitor BenQ XL2730Z 144Hz 1440P | KB Corsair K70 LUX | Mouse Logitech G402 | Headset  Logitech G933
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382549
wat
literally any ddr4 above 2133 is overclocked. xmp just sets a overclock thats 100% stable. overclocking memory is totally fine.
@WeeMan85
did you try to enter the primary timings manually? (cl15-15-15-35-T2 for example and select 3000mhz for frequency) xmp doesnt set secondary or tertiary timings anyway. you might need to tweak a little voltage on your vccsa (system agent voltage, but shouldnt be more than 50mv on skylake) adding 25mv to your dram voltage can  increase stability too.
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382560
What RAM did you get?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382573
You might need to increase the system agent voltage. Give it another 50mV or so.
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382594
24 minutes ago, Minsekt said:
wat
@WeeMan85
I will have a look at this tonight when I get in thanks
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382671
5 minutes ago, WeeMan85 said:
Corsair dominator platinum
Hmm, sorry don't have any experience of this myself.. had a look at a few reviews that seem to suggest that the RAM could be unstable, a few people have had problems trying to get it to run at that speed. How long have you had the sticks?  if you haven't had them long I would be tempted to return them and get something different.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382726
1 hour ago, Minsekt said:
wat
@WeeMan85
I would do this bit it mite be me and I'd hate to look a fool lol
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7382907
Highly not recommended by who? You? The only people who do not recommend memory overclocking are the people that do not know how to overclock memory.
wat
@WeeMan85
Solid advice here. You do not want to have VCCIO/VCCSA running beyond 1.25v for 24/7. I personally do not recommend running over 1.15v, as you can technically make it run with less voltage by slightly loosening certain tertiary timings, with little impact on overall bandwidth.
2 hours ago, WeeMan85 said:
I am new to overclocking and just bought a,  Gigabyte g1 z170 motherboard,  an i5 6000k with 16gb of 3000mhz memory and cant seem to get it to run at the the aforementioned speed or in XMP mode, is it the same as a CPU where as I need to tweak the voltage?
You may want to look into turning MRC Fast Boot off. I dislike the way it handles previously trained timings. I would do that first, then follow the advice given by Minsekt above.
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7383006
What BIOS version are you running? Some early revision BIOS's had limited/poorly implemented XMP support (this goes for nearly all the manufacturers). I'd only run the BIOS update if you see more recent versions that specifically site memory/XMP support updates.
This should be as simple as hitting the XMP drop-down menu and choosing your speed divider.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7383414
4 hours ago, Minsekt said:
wat
@WeeMan85
I'm going to research all what you have set about adjusting the timings manually because I have no idea how to go about doing it
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7383926
In theory yes, in pratice it's a bit more finnicky. A lot of Z170 boards have issues with XMP. Setting it will result in a failed OC on boot. Usually not on 500 dollar boards though.
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7383933
failed for what reasons? I haven't had any XMP issues with my OC Formula w/i3-6100 or the 6600k :| I do always manually key in my voltage values though.
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7384990
Well i have some results i have XMP working but not at the specified speed as memory suggests (3000mhz) i have it running at 2800mhz in XMP but any higher and PC wont post. this is as far as my memory knowledge goes as of now and i have updated BIOS.
Is the DRAM voltage being adjusted to match the XMP specs? If it has try notching up the RAM voltage by .01-.02v and keying manually.
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7384998
Some boards can't handle the memory overclock and they will give you the error message OC failed. XMP is a factory defined overclock of the memory. It's mostly the cheaper boards that have problems with XMP. More expensive boards with better power delivery system (more phases for CPU and mem etc) have less issues.
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7389505
It just won't post
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7390039
On 7/3/2016 at 2:32 PM, Minsekt said:
wat
I mean manually, messing with timings and everything.
https://linustechtips.com/topic/561153-3000mhz-memory/#findComment-7418664
