So I have a project that involves powering a monitor and desktop motherboard from six lithium batteries. The problem I have is that the monitor needed 16vDC so I could not use one of the rails from the main PSU, an M2-ATX-HV. The monitor is therefore driven off of a cheap buck regulator from China. Here is an image of it:
The heatsink on the inductor and the bottom of the board are my mods, the board has been electrically insulated from the heatsink.
I noticed a possible problem though:
The ground rail appears to have a diode on it.
Anyway, the issue is that the monitor (VGA only) is displaying a lot of scrolling lines on it, and it only happens when the PC and monitor are driven off of their respective supplies connected to the same battery pack. If I connect the monitor through the buck regulator to my bench supply, the scrolling lines go away. I hate VGA.
What would be the solution here? The ATX supply and buck regulator share a power source, and I think we are getting power flowing through the VGA cable's shield, causing interference. I tried putting a common mode choke on the input of the monitor with a 470uf capacitor, and it did not make much of a difference.
Could it be that diode on the DC/DC letting power flow through the shield on the video cable instead of the diode? I haven't the slightest idea on where to begin.
https://linustechtips.com/topic/560784-fixing-a-ground-loop/
did you try running the monitor with 12v?
a lot of the time electronics will work with voltage below what is specified
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7378642
Could you use a ground loop isolator that is usualy used for audio?
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7378647
Cuts off at 13. Already tried it. Dad got the monitor for 5 bucks off Craigslist because the PSU was missing. It normally takes 14v. I run it off of 16v for a while, takes less current because the voltage is higher. With my scope I am seeing about 1v of ripple on the input to the main ATX supply...
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7378670
Unfortunately no as this is a DC power signal not an AC line level signal. If they made one for the video however, it would probably work but would look terrible
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7378678
Ah, just thinking, as I had one spare that i could have sent to you with keyboards.
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7378684
Ya. Considering the amount of ripple coming from the ATX DC/DC, I feel like putting common mode chokes everywhere to see what happens
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7378708
2 minutes ago, Scheer said:
Have you tried bridging from the -5 and 12v, which would effectively give you 17v?
It will likely pull more power than the -5v can give though...
Likely wouldnt carry enough power, my DC/DC likely doesnt have it, and that would set the monitor's ground 5v below VGA ground, which basically means shorting out the -5v rail
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7387764
might need a dc filter choke depending on the kind of interference that is being caused. If you have a oscilloscope it would be pretty easy to figure out a solution.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7391662
I do, a brand new DS1054Z :D
https://linustechtips.com/topic/560784-fixing-a-ground-loop/#findComment-7391695
