I was reading on Reddit that they only had 5000 in stock but 100k shafts to hopefully that means more will be made but I'd like confirmation on this myself!
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
1 hour ago, TempestCatto said:
Damn I had no idea it was finally released! I really wanted one, hoping they're not a limited run 😞
ALL items are limited run 😁
But anyways like the other poster said, these pens are made using their inventory of 100K bad screwdriver shafts, so there will definitely be more in stock and they are likely just releasing in batches.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
But it takes two to make one pen, so at most they can only make 50,000 pens. So, once they go through their fail screwdrivers, if they wanted to make more they would have to physically order the driver shafts.
