[HELP] C++ while true loop
Go to solution Solved by Nineshadow,
Your code has quite a few very obvious syntax issues.
Anyway :
#include <iostream>
using namespace std;
main()
    int usersGuess;
    cout << "I'm thinking of a number between 1-100\n";
    cout << "Guess what it is: ";
    cin >> usersGuess;
    while(true)
        if( usersGuess == 7) break;
        if( usersGuess > 7 )
            cout << "That's too high.\n";
            cin >> usersGuess;
        if( usersGuess < 7)
            cout << "That's too low.\n";
            cin >> usersGuess;
    cout << "Jackpot!";
This should fix it.
Learn the proper if statement syntax in C :
if(<condition>)
<instructions>
#include <iomanip>
#include <iostream>
#include <cmath>
main() {
    int usersGuess; //
    cin >> usersGuess;
    cin.ignore(1000, 10);
    while(true) {
    if( usersGuess == 7) break; // see if the guess is right
    if( usersGuess > 7 );
    cin >> usersGuess;
    if( usersGuess < 7);
    cout << "Jackpot!";
If I input greater than 7 it should say it "That's too high".
The problem is if I input greater than 7 again it says "That's too low" when it should have been that's too high.
Im confused
Yeah, we're all just a bunch of idiots experiencing nothing more than the placebo effect.
https://linustechtips.com/topic/559572-help-c-while-true-loop/
first use elif and else statements instead of just going if if if all the time
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7364995
Quote
#include <iomanip>
#include <iostream>
#include <string>
#include <cmath>
main() {
    int usersGuess; //
    cin >> usersGuess;
    while(true) {
    elif( usersGuess > 7 );
    cin >> usersGuess;
    else;
Maybe as @Enderman said, like this
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365019
Quote
#include <iomanip>
#include <iostream>
#include <string>
#include <cmath>
main() {
    int usersGuess; //
    cin >> usersGuess;
    while(true) {
       cin >> usersGuess;
    else if( usersGuess < 7)
    else;
       break;
Maybe switch the values around so that break is the last option.
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365137
This is what your code is doing
( the semicolons after the if expressions mean that they do nothing)
    cin >> usersGuess;
    while(true) {
    if( usersGuess == 7) { break; } // see if the guess is right
    if( usersGuess > 7 ){
        // do nothing
    cin >> usersGuess;
    if( usersGuess < 7){
        // do nothing
You should use braces like this:
while(true) {
    cin >> usersGuess;
    }else if( usersGuess < 7){
    }else{ // usersGuess == 7
    	break;
I remain,
msevilgenius
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365207
I can't do that because the break should be initiated if the correct answer is guess which is 7.
The problem is I want to keep looping "That's too high" if the user inputs greater than 7 and skip the "That's too low".
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365230
Then replace else with else if from the last code revision or @msevilgenius suggestion and include another else with the loop call, I'm not sure if c++ uses it though, I'm a python guy
maybe this is a problem?
http://www.cplusplus.com/forum/beginner/144641/
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365291
If nothing else heres a loop from another article that has claimed to work, you'd need to replace the int number from the random pattern to the number you want (7)
Quote
#include <iostream>
#include <cstdlib>
#include <ctime>
int main(void) {
	srand(time(NULL)); // To not have the same numbers over and over again.
	while(true) { // Main loop.
		// Initialize and allocate.
		int number = rand() % 99 + 2; // System number is stored in here.
		int guess; // User guess is stored in here.
		int tries = 0; // Number of tries is stored here.
		char answer; // User answer to question is stored here.
		//std::cout << number << "\n"; // Was used for debug...
		while(true) { // Get user number loop.
			// Get number.
			std::cout << "Enter a number between 1 and 100 (" << 20 - tries << " tries left): ";
			std::cin >> guess;
			std::cin.ignore();
			// Check is tries are taken up.
			if(tries >= 20) {
				break;
			// Check number.
			if(guess > number) {
				std::cout << "Too high! Try again.\n";
			} else if(guess < number) {
				std::cout << "Too low! Try again.\n";
			} else {
				break;
			// If not number, increment tries.
			tries++;
		// Check for tries.
		if(tries >= 20) {
			std::cout << "You ran out of tries!\n\n";
		} else {
			// Or, user won.
			std::cout<<"Congratulations!! " << std::endl;
			std::cout<<"You got the right number in " << tries << " tries!\n";
		while(true) { // Loop to ask user is he/she would like to play again.
			// Get user response.
			std::cout << "Would you like to play again (Y/N)? ";
			std::cin >> answer;
			std::cin.ignore();
			// Check if proper response.
			if(answer == 'n' || answer == 'N' || answer == 'y' || answer == 'Y') {
				break;
			} else {
				std::cout << "Please enter \'Y\' or \'N\'...\n";
		// Check user's input and run again or exit;
		if(answer == 'n' || answer == 'N') {
			std::cout << "Thank you for playing!";
			break;
		} else {
			std::cout << "\n\n\n";
	// Safely exit.
	std::cout << "\n\nEnter anything to exit. . . ";
	std::cin.ignore();
	return 0;
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365372
Anyway :
#include <iostream>
main()
    int usersGuess;
    cin >> usersGuess;
    while(true)
            cin >> usersGuess;
        if( usersGuess < 7)
            cin >> usersGuess;
    cout << "Jackpot!";
This should fix it.
if(<condition>)
<instructions>
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365422
Anyway :
#include <iostream>
main()
    int usersGuess;
    cin >> usersGuess;
    while(true)
            cin >> usersGuess;
        if( usersGuess < 7)
            cin >> usersGuess;
    cout << "Jackpot!";
This should fix it.
Holy crap it did fixed it :D
BTW why did you not use cin.ignore(1000, 10)?
my Prof always says to include it when making a prompt.
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365459
It won't really make much of a difference here honestly.
Cin leaves the newline character in the stream. Adding cin.ignore() to the next line clears/ignores the newline from the stream. This is used mainly with combinations of cin and getline.
https://linustechtips.com/topic/559572-help-c-while-true-loop/#findComment-7365472
