go search some OC Tutorial Video, Linus has some actually, never touch Voltage if you don't know what are you doing, so does with Custom BIOS, if you're going to OC for Benchmark i recommend to use 100% on Fan, but for gaming 70% is the Sweet Spot
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/558987-oc-gtx-970-hof-help/#findComment-7355197
The voltage settings in your bios won't allow for much adjustment with normal tools....if it all, if I recall correctly.  As long as your temps are ok, you should be good up to 1.282v.  Though, as I said, I'm 99% certain your stock bios won't allow for that much anyway.
Any time you overclock, put the power target slider to max.  Try +100 core, and +300 memory, and adjust from there.
Use GPUz sensors tab.  It's critical in getting a good overclock on the Maxwell series cards.  Watch the PerfCap Reason line, specifically.  You're watching for, and hoping not to see green.  Green indicates the "PWR" perf cap.  Power limit....if you see that in your testing, you will either need to lower your clocks / voltage, OR, flash to a custom bios.
If you start hitting the power limit perf cap post back here, and we can help you adjust to get around it.
CPU: Ryzen 1600X @ 4.15ghz  MB: ASUS Crosshair VI Mem: 32GB GSkill TridenZ 3200
GPU: 1080 FTW PSU: EVGA SuperNova 1000P2 / EVGA SuperNova 750P2  SSD: 512GB Samsung 950 PRO
HD: 2 x 1TB WD Black in RAID 0  Cooling: Custom cooling loop on CPU and GPU  OS: Windows 10
https://linustechtips.com/topic/558987-oc-gtx-970-hof-help/#findComment-7355339
