HELP
So in late November i built my first PC build which you can find here: http://pcpartpicker.com/p/q3C4K8
And now I am looking to upgrade, here are my plans. http://pcpartpicker.com/p/9PkD6h
Now if you didn't notice, it was missing a PC case. I have been looking at tons of different cases but just can't decide!
I really like the compact designs of cases like the Corsair Carbide Air 240 or the Bitfenix prodigy M, But i don't want to be limited by 2 expansion slots. I also would like sufficient air flow and some type of side panel window, although it does not need to be very big.
Anyways I was looking for some help in choosing the right PC case for my system.
What Do You Think?
2 minutes ago, mitchelskater said:
Windows 7 Will always be better than Windows 8 or 10.
Other things: Maybe get an 850 Watt or so power supply just to make sure it's up gradable?
Didn't really solve his question. Regradless support for win7 will end before long so good luck with that.
This should work
http://pcpartpicker.com/part/raidmax-case-atx818wb
My personal desire
http://pcpartpicker.com/part/thermaltake-case-vn40006w2n
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[i7-7700k@5Ghz | MSI Z270 M7 | 16GB 3000 GEIL EVOX | STRIX ROG 1060 OC 6G | EVGA G2 650W | ROSEWILL B2 SPIRIT | SANDISK 256GB M2 | 4x 1TB Seagate Barracudas RAID 10 ]
[i3-4360 | mini-itx potato | 4gb DDR3-1600 | 8tb wd red | 250gb seagate| Debian 9 ]
[Dell Inspiron 15 5567]
I mean i was looking more for help finding a new pc case, hense the " Anyways I was looking for some help in choosing the right PC case for my system. " but thanks?
I recommend you just go for a 750 watt PSU instead of just getting a new one with the same wattage. Also Pascal GPUs and the new Radeon GPUs are coming out later this year, why not wait for those? The performance boost from your 780 to a new Pascal GPU will be much greater than a 390X. I have one and compared to a 780 on GTA V, the game you play the most, as shown by your steam profile...             they perform almost exactly the same. Here, I made a pcpartpicker list of my recommendations   http://pcpartpicker.com/p/L2Wzzy
OK! IFIXED IT, YES I KNOW KITKATCAM, Dill with it,
Edited by 3002vwac
