I need a psu and a case
Plz recommend a good psu and case- here r my components(planning to build a pc) Any other recommendations (Tnx)
AMD FD8320FRHKBOX FX-8320 FX-Series 8-Core Black Edition Processor
EVGA GeForce GTX 750Ti SC 2GB GDDR5 Graphics Card 02G-P4-3753-KR
MSI 970 GAMING DDR3 2133 ATX AMD Motherboard
LG Electronics Internal Super Multi Drive Optical Drives GH24NSC0B
WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD10EZEX
Kingston HyperX FURY 8GB 1866MHz DDR3 CL10 DIMM - Blue (HX318C10F/8)
NZXT S340
Corsair CX 500W
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
4 minutes ago, Vercii said:
NZXT S340
Corsair CX 500W
No, the CX is not a good PSU by any means, there are much better options that are more reliable. Your case selection is fine though.
@OP a 500W SeaSonic/XFX PSU would be more than enough for your build.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
2 minutes ago, Jordan Joseph said:
do u think 500w is enough?
Yes.
Novus Anima
Laptops
Surface Pro 3
Easily enough, will only draw like 200w from the wall. Whats your overall budget for the pc aswell and whats its purpose(eg gaming or editing ect)
CPU: Intel I5 4690K | GPU: Asus R9 280x | PSU: Evga 600w | RAM:8GB DDR3 | HDD: WD 1TB | HDD: WD 500GB | SSD: Sandisk 120GB
I only said 500W because you may want to upgrade in the future.
Novus Anima
Laptops
Surface Pro 3
I know the best case ever, I've been using it for a while... it's a piece of chipboard with mounting holes. It works amazingly pics coming from phone in 2 mins
6 minutes ago, Jordan Joseph said:
overall budget $600 gaming
Going a bit offtopic, but you might want to change the GPU to gtx 950 or something
I5 4460 | Sapphire RX480 Nitro | MSI H81M-E34 | 8 GB | Fractal Design Core 2500 | Silverstone SST-ST50F-PB | Monitor 27-inch EW2750 | Roccat SKELTR+ (giveaway from linus)
My six year old (second rig):
CPU: Intel Core 2 Duo E8400 | GPU: 1024MB NVIDIA GT 730 under-powered gigabyte GeForce 9800 GT (Gigabyte OP Silent cell stuff) | 4GB Dual-Channel DDR2 @ 399MHz | MOBO: Intel DP43TF |
EVGA 500 W1 80+, 500W Continuous Power, 3 Year Warranty Power Supply 100-W1-0500-KR  is this one good?
37 minutes ago, Vercii said:
NZXT S340
Corsair CX 500W
i need a dvd drive slot
Nah, get an XFX TS.
OK, what do you need it for? If it's for installing Windows you can just use an 8GB flash drive.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
On 2/28/2016 at 11:35 PM, STRMfrmXMN said:
Nah, get an XFX TS.
not only that- games, videos r on a lot of discs so that why
of course, u have a 750 ti and AMD stuff, get 500w or even a 430w power supply
