Why not using car coolant?
Solved by airdeano,
automotive coolant is designed for the automotive uses it needs:
extreme temperature usages (hot and cold)
mixed metal usages
extended use
using automotive coolants can be used, but only with rated parts.
the tubing we use is not rated for automotive coolant, the acrylics are not, PETG is not rated for this type of glycol and some rubber items used are not specific for automotive coolant use.
for auto/truck the normal antifreeze/coolants were 50:1 ratio to provide specific cooling tasks.
the newer extended formulas are more suitable for aluminum, but not so harsh to include cast iron, steel, or ferrous metals.
as to different coolants tried:
